Activity Forums Media 100 Episode not seeing M100 V12 black clips!
  • Episode not seeing M100 V12 black clips!
    Posted by Andy Taplin on November 27, 2007 at 2:23 pm
    Hi All
    Just got V12 up and running on a new MacPro 8 core and the first issue I’ve come across is that black clips don’t seem to be recognized by Episode.
    So if you have say a 2 sec black clip at the start of a programe Episode screws up the encode and you get some noise instead of picture. This happens if I export as by-ref or self-contained.
    The export plays fine in QuickTime though.
    If I use a bit of AFX rendered black the clip encodes normally.
    Anyone have any ideas about this before I go to the Telestream forum?
    Andy Taplin replied 18 years, 9 months ago 3 Members · 3 Replies
  • Floh Peters
    November 27, 2007 at 2:27 pm
    Media 100 does something really clever and totally legal (in terms of QuickTime use): for black clips it uses small 2*2 pixel large clips that get embedded into the by-ref or self-contained exports. This greatly reduces filesize, but unfortunately there are many QuickTime-based apps (including Compressor, see thread below) that don
  • Gregg Michaels
    November 27, 2007 at 2:56 pm
    I have been working on this problem for 2 months on the Telestream side. They couldn’t come up with a solution. After I got rid of the Media100 black, the encodes all work! Thanks for the workaround!!
  • Andy Taplin
    November 27, 2007 at 4:08 pm
    Thanks Floh
    That makes sense – I just tried a blue clip and you can see it as a pinprick in Episode!
