Activity Forums Compression Techniques Episode for DVD studio Pro
  • Episode for DVD studio Pro
    Posted by Nick Franco on January 7, 2007 at 7:03 pm
    Hi All
    i understand (wright or wrong) that Episode is beter than FCS compressor for all compression, bearing this in mind i’m having a nightmare trying to get episode to export a file that DVD studio Pro understands. i use the .mv2 file and ive tried all 5 and 7 bit rates and DVD studio Pro dos’nt like to import them. have i missed something?
    i’m using a pal system
    your help would be most appriciated
    Francesco pio Tessarolo replied 14 years, 10 months ago 4 Members · 3 Replies
  • Charles Simonson
    January 8, 2007 at 9:10 pm
    FYI, Compressor 2 has a fine MPEG-2 encoder. I wouldn’t say it is necessarily any better or worse than Episode’s MPEG-2 encoder. If you are having issues with Episode, make sure you are running the latest version of Episode, which is 4.2.1 and recently included some fixes for DVDSP compatibility; if that doesn’t solve it, then go back to Compressor or contact Episode support. Their email support team is usually very good.
  • Clayton Woodhull
    February 28, 2007 at 1:37 am
    I am not able to import mpeg2’s at 23.98 into DVD Studio Pro from Episode Pro but clips at 29.97 import fine. I get the error message “Incompatible Format”. Has anyone figured out a solution to this?
    Episode Pro 4.2.1
    DVD Studio Pro 4.1.1
    Clayton
  • Francesco pio Tessarolo
    October 28, 2011 at 4:55 am
    the solution is trash episode and using another sw. I’ve tried to contact support and they are evasive…
