Activity › Forums › Adobe After Effects › Ephemerally Occluded Parts – How to Mask Them?
  • Pierre Jasmin
    March 27, 2017 at 2:25 pm
    1) For the manual:
    https://revisionfx.com/faq/where-is-the-plug-ins-manual-installed/
    2) The arm in your example might work better as a separate layer
    Pierre
  • Roland R. kahlenberg
    March 27, 2017 at 2:44 pm
    Ah! Noted!!! Pierre, I’ve only vaguely looked/read the doc on working with a separate layer – will look into it as soon as I can. From my vague memory, I’ll have to roto out the hand in both shots – correct?
    I’m still thinking a top-down (mask Timeline hierarchy) hierarchy might be a better/elegant solution.
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
    March 29, 2017 at 3:55 pm
    Thanks for the link Pierre. I’ve also managed to create the morph without separating to layers. Simply masking the various facial features and outline did the trick.
    Cheers
    – Roland
  • Pierre Jasmin
    March 29, 2017 at 9:02 pm
    Great! – turns out blind techsupport is hard ☺ — pierre
