¿Pan/crop Lags? I want to improve my vegas experience
Hello everyone.
I have been editing with Sony Vegas for years, maybe 4 or 5. I’m used to the lags / slow rendering when I’m working with long footage, but I really want to impove it now, as I’m working as an editor and I could edit faster if I optimice some settings, I’m sure.
I assume I’m having a bottleneck issue somewhere on my laptop, or there is something I can change to make it work properly, because my laptop has good specs and I should’t have problems while editing. I don’t really mind the rendering time as I do other things while I’m rendering. The problem is that I don’t want to deal with lags while I’m editing.
The main problems I have are this ones:
When I select the opcion pan/crop, or when I insert a new effect, or when I create a new text, my computer takes 4-5 seconds to open each window with the details of the effect, the pan/crop view, etc. It freezes for 5 secs and then it shows the view. Also: When I create new frames in the pan/crop event, sometimes it works smooth, some times it takes ages to render while I’m moving the frame dots to find a particulary spot. So this ends up on me guessing where the dots should be without even checking, then CLOSING the pan/crop view because I can’t see anything if that view is open ( The sound works ok, but the video frame doesn’t change, so I must close the pan/crop to see the video. this is painful aswell) and then watching If my guess was ok. If not, I have to open the pan/crop view again and replace the dots… ugh.
Important Note: When I switch off and then turn on the computer, and open a new sony vegas project, it usually works smooth for the first 10-15 mins. Then all the problems start to happen again. So that’s why I think I have a bottleneck issue or something not related with Vegas, I don’t know.
My specs: my laptop is MSI GL73 8RD. Basically it has 512 gb ssd, 1 TB Hdd, 16gb Ram(wanna improve this to 32gb in a few days…), 1050 gtx ti , i7-8750H 2.20 Ghz, windows 10.
Also! I’m using Sony Vegas 15.
TLDR: If you ever had lags in sony vegas while opening pan/crop event and creating/moving frame dots, and you fixed it, tell me how 🙁
