Activity › Forums › DSLR Video › EOS plugin for Final Cut is out!
Posted by Chris Paul on March 19, 2010 at 4:23 pmThe EOS MOVIE Plugin-E1 for Final Cut Pro is out. It allows using the Final Cut log and transfer window to directly import Canon H264 video from CF cards via conversion to ProRes. Here is the link:
Chris Paul
POVChris Mccorkel replied 13 years, 4 months ago 18 Members · 39 Replies -
Göran Thorén
March 19, 2010 at 4:36 pmWow, taht’s great news! Thank’s for the heads up Chris!
Göran
Chris Paul
March 19, 2010 at 5:07 pmIf you are like me and have not used the Log & Transfer window much, be sure to set the import preferences to the format you really want. On first use it defaults to 444.
Chris Paul
POV -
Stephen Smith
March 19, 2010 at 5:56 pm -
Declan Smith
March 19, 2010 at 9:10 pmI have installed the plugin but can’t get it to work
I just get
“103EOS7D” contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media.
Yet this has all the 7D movs in ?
Any ideas what I am doing wrong ?
Declan Smith
https://www.madpanic.tv
FCS3 / After Effects CS4 / Combustion / Canon 7D / Canon XL2 -
Declan Smith
March 19, 2010 at 9:39 pmOk found out what was wrong.
1. You must have the .THM files to go with the video, otherwise the plugin won’t recognise the clip.
2. You can’t trick it by just creating a .THM from a text editor, this will cause FCP to crash
3. If you have lost the .THM files (like I have) you can just copy a working one to the same name as the movie file, but with a .THM extension. The picture and exif info will be wrong but if will show up in the log and transfer window.Anyone know how to recreate the .THM files properly ?
Declan Smith
Noah Kadner
March 20, 2010 at 12:09 amSweetness- trying now.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio. -
C. Kauffman
March 20, 2010 at 9:10 pmIs this any faster or better quality than converting to ProRess with MPEGstreamclip?
Sony EX1
Canon 5d mark 2
FCP 6.06 -
Declan Smith
March 20, 2010 at 9:33 pmI don’t think it us any faster it better quality than mpeg streamclip, but once integrated into the log and transfer window, you can now link your media clips to the source material in fcp.
I have put together a short workflow tutorial that may be of interest. I dud this as I wanted a similar workflow to tape and be able to backup and catalog my sd captured clips.
hope this is of some use.
Declan Smith
Bill Davis
March 20, 2010 at 9:41 pmI find it a heck of a lot faster than before. Now, it’s just launch log and transfer and pop in your CF card. The card files show up in the FCP log and transfer window and allow you to select the clips you do or don’t want to transcode. Mark the files and the batch starts. The new clips show up transcoded right in your designated FCP logging bin.
This has improved my workflow a LOT.
