Activity Forums Adobe After Effects Environment Layer issue
  • Environment Layer issue
    Posted by Hannah Sander on November 19, 2014 at 11:21 pm
    Hello,
    I’m attempting to make an Environment Layer for the first time after watching some tutorials.
    However, when I right click and select “Environment Layer” my layer completely disappears.
    I have the layer (and mode) set to 3D, and I have “Ray-traced 3D” rendering enabled. I’m following the tutorials verbatim, so I literally have no idea what’s going on.
    Any ideas?
    Brian Charles replied 11 years, 10 months ago 2 Members · 7 Replies
  • 7 Replies
  • Hannah Sander
    November 19, 2014 at 11:31 pm
    Thanks for the reply!
    I’m using CS6. Most of the tutorials I followed were for CS6 as well.
  • Brian Charles
    November 20, 2014 at 10:59 am
    You need to add a camera for the environment layer to work.
    See the attached file.
    8205_enviro.aep.zip
    While its true that Adobe have abandoned further development of RayTracing in After Effects, I don’t agree with Dave’s characterization of the RayTraced renderer, I still used RayTraced 3D for some work.
    However, C4D is far more capable.
  • Hannah Sander
    November 21, 2014 at 5:07 pm
    Thank you so much for the example, Brian! I was able to open it up and have all the layers work perfectly.
    However, when I opened a new composition and mimicked exactly what your layers were, my environment layer still disappeared! Is there a specific order I need to do it in?
    I made my solid layer with a fractal noise effect, then made a new camera and text layer. I made them 3D enabled. I have ray-traced enabled. I then pre-composed my background layer before right clicking and selecting “environment layer.” My background layer then goes black.
    It just seems so straightforward, I can’t imagine where I’m messing up!
  • Brian Charles
    November 21, 2014 at 7:55 pm
    Here’s a demo.
    Is the Comp panel set to Active Camera?
    ENV2
  • Hannah Sander
    November 21, 2014 at 9:28 pm
    Thanks Brian,
    Here is what I just attempted:
    Environment Layer test
    When it goes to black (or checkerboard, when I have the BG set to transparent…) I can’t rotate with the camera or anything. It’s just like the layer vanished.
  • Hannah Sander
    November 21, 2014 at 9:42 pm
    OH MY GOODNESS! I went back and studied the sample project you gave me and realized I was clicking the “Draft 3D” button (because that’s what I thought I had to have selected to enable 3D layers…) AND HUZZAH! It worked!
    Thank you so much for all the help, Brian!
  • Brian Charles
    November 21, 2014 at 10:22 pm
    [Hannah Sander] “realized I was clicking the “Draft 3D” button”
    That would do it! I done similar things myself, its how I learn.
