Activity Forums VEGAS Pro Envelopes missing
  • Envelopes missing
    Posted by Videochicke on October 5, 2007 at 1:11 pm
    When I right click on the video bus in Vegas 5 and select insert/remove envelopes, only 3 choices show. (Mute, Composite Level, and Fade to Color). Under the view menu, all 8 items are checked under video envelopes. Under the insert menu on top, I see 2 additional choices (velocity and transition progress). How do I get the additional envelopes to appear? If I uncheck what already appears, it changes nothing. The same choices are always there. Thanks!
    Julie
    Cactusvac replied 18 years, 11 months ago 3 Members · 3 Replies
  • Cactusvac
    October 9, 2007 at 3:59 pm
    I have exactly the same problem.Im on vegas 7.0d.Please help!
  • Edward Troxel
    October 9, 2007 at 5:34 pm
    [Videochicke] “I see 2 additional choices (velocity and transition progress).”
    Velocity envelopes have to be added to an event.
    Transition envelopes ahve to be added to a transition.
    Edward Troxel
    JETDV Scripts
  • Cactusvac
    October 9, 2007 at 6:10 pm
    solution:these options are available for a bus video track but not a standard video track.Go view—>view video bus track and it will appear at the bottom under the standard video and audio tracks.The missing envelopes can be found there.
