Activity Forums Boris FX Particle Illusion Entering Atmosphere
  • Entering Atmosphere
    Posted by Jamie Young on June 7, 2009 at 7:13 pm
    Ok so I have an animation of a ship flying through space, then it cuts to flying through the atmosphere, what I am looking for is a particle effect that I could place in front of the ship to giv that realistic look of flying or falling through the atmosphere. I believe most of the people here know what I am meaning. If anyone could help that would be great. I am currently going through my librarys but have found nothing yet.
    Thanks.
    Jamie.
    Clive Knowles replied 17 years, 1 month ago 3 Members · 4 Replies
  • Jack Evans
    June 11, 2009 at 11:01 pm
    I think it depends on how much heat you want to simulate. I’d start with one of the “burning sword” emitters (from the July ’06 library, IIRC), and turn off the sparks. You might have to change the weight over life so that the smok stays along the path of the ship instead of rising so quickly, but I think that’s be an effective place to begin.
  • Jamie Young
    June 13, 2009 at 7:54 pm
    Thanks. where can I get the old library from.
  • Jack Evans
    June 13, 2009 at 9:43 pm
    If you’ve never downloaded it, you can get it by clicking on Check for Updates in the PI help menu; it’ll show up in the list of free emitter libraries to download. The one I was referring to is named emitters_06_07. Once you download it from the update program, you should be able to bring it up with the Quick Load Library option from the libraries window.
  • Clive Knowles
    July 11, 2009 at 12:25 am
    There’s an emitter ( user_00_05.iel ) that simulates what you want..the actual name of it is “Entering Atmosphere Fire” .
    Hope it helps….it’s in the library “Users, May 2000”
