Activity › Forums › Apple Final Cut Pro › Enlarging Audio Track
Posted by Ray Bright on August 23, 2018 at 2:44 pmI used FCP 15 years ago, you could then blow up the audio track so large you could see each wave top and bottom clearly. But the latest v doesn’t allow me to blow it up that far, or more likely, I just can’t figure out how to blow it up. I have a tiny clink I need to remove but I can’t zero in on it at max zoom. How do I blow the soundtrack up as big as I can?
Ray
Steve Connor replied 8 years ago 5 Members · 7 Replies -
Mike Lemons
August 24, 2018 at 9:49 amSelect the audio clip and hit Command and + key
Is that what you mean?Frosties are just Cornflakes for people who cant handle reality.
Ray Bright
August 24, 2018 at 3:54 pmNo. That allows you to enlarge the sound track by a fraction of what it used to. The current max enlargement is useless in extremely precise editing, like removing a single pop or rustle.
There are external programs that allow for blowing up that’s useful, but those used to be available within FCP. Looks like another upgrade, that …isn’t.
Ray
Scott Witthaus
August 24, 2018 at 7:17 pmFCPX can do that, as Steve demonstrated. Another feature…that is.
Scott Witthaus
Visual Storyteller – FCPX, Premiere
https://vimeo.com/channels/1322525
Managing Partner, Low Country Creative LLC
Professor, VCU Brandcenter -
Joe Marler
August 25, 2018 at 11:20 am[Ray Bright] “The current max enlargement is useless in extremely precise editing, like removing a single pop or rustle….”
This Ripple Training tutorial shows how to navigate by 1/80th of a frame, and do sample-accurate audio editing in FCPX. However it must be a connected audio clip or compound clip that contains only audio.
Also the menu option View > Zoom to Samples must be enabled.
https://support.apple.com/kb/PH12569?locale=en_US&viewlocale=en_US
MacBreak Studio #225: https://www.youtube.com/watch?v=POlbuVkoTkI
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Ray Bright
August 27, 2018 at 7:51 pmLooks like View>Zoom to Sample will have to do. Old FCP used a Plug-in that came with it that allowed you to move in to key frame and manipulate the wave on a tiny scale. I trying to remove a ‘clink’ against my mic on an otherwise perfect clip.
Ray -
Steve Connor
August 27, 2018 at 8:02 pm[Ray Bright] “Looks like View>Zoom to Sample will have to do.”
I don’t know about “have to do” it actually does exactly what you need
[Ray Bright] “Old FCP used a Plug-in that came with it that allowed you to move in to key frame and manipulate the wave on a tiny scale.”
and “new” FCPX does the same thing without having to get a plug-in ☺
[Ray Bright] ” I trying to remove a ‘clink’ against my mic on an otherwise perfect clip.
“Easily done with “zoom to sample” you can keyframe at sample level easily.
