Activity › Forums › Sony Cameras › enhancement changes between ND filter 1 and 2
Posted by Bob Glusic on April 11, 2008 at 6:08 pmJust wondering if anyone noticed a difference in sharpness or detail when switching between ND filter 1 and 2? Filter 2 in an outdoor sunny scene looks fine but if I switch to filter 1 I loose detail or sharpening (about 20%). I’ve tested 2 cameras with the same results.
Thank,
BobJim Watt replied 18 years, 4 months ago 4 Members · 4 Replies -
Noah Kadner
April 12, 2008 at 5:08 amAre you sure that’s not do in part to the change in exposure the ND switch mandates? All lenses have a sweet spot where at a certain point in the iris range they are sharper than others- usually somewhere around the middle is best- like f4-f8.
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the Sony EX1 Guidebook
https://www.callboxlive.com -
Alan Lacey
April 13, 2008 at 9:33 amThere’s been postings here about a back focus issue with the EX1 and the ND filters. Can’t say I’ve noticed it myself but mine’s of of the recent ones.
I hope I don’t regret not waiting for the EX3???
Alan
Bob Glusic
April 13, 2008 at 5:50 pmI plan on sending Sony 2 still captures of the same subject just different ND filters to show them the difference.
Bob -
Jim Watt
April 15, 2008 at 4:50 pmI’ve noticed some “strangeness” in focus a few times in screening material we recently shot. It seems and this is assuming I didn’t screw up and refocus…shots that are under exposed, go soft. Since this is way after the fact, I have no idea which filter I was on, but interiors, in theory would be with no ND or ND 1, and exteriors with at least ND 1.
I know this sounds wrong, in theory if they were under exposed the iris would be giving more depth of field, but it has happened several times and I don’t think or at least I hope I didn’t miss the focus that far.
I’ve been too busy to make some sort of analytical test, but in 24 hours of video I don’t expect to get a half dozen shots that are soft.
jw
Producer/DP, HD series, “Discoveries…America”, “Discoveries…Ireland”, “Discoveries…Spain”,
“Discoveries…Argentina”
