Activity › Forums › Maxon Cinema 4D › Engraved text on sphere
Posted by Pravin Chottera on June 16, 2009 at 4:57 pmI need to engrave text onto a sphere, and realize I have no idea how to do it. Help?
Chris Brandt replied 16 years, 6 months ago 3 Members · 2 Replies -
Brian Jones
June 17, 2009 at 12:43 ama couple possibilities (might be more)
– create the text (an extrude), use the Wrap deformer to wrap the text around a sphere and use a boolean to cut the text from the sphere
– use displacement (sub-poly displacement probably) in a material to “cut” the sphere, the displacement map of the text would have to be big enough so it is clean enough (not chunky at the edges)
Chris Brandt
March 18, 2010 at 11:49 pmJust a more detailed follow-up on Brian’s post (even though it’s several months old), since I was looking for the same info, and this was one of the first Google links. I then had to do a further search for the details. 🙂
After creating and extruding the text, in the main menu, go to Objects > Deformation > Wrap. In the Objects list, nest the Wrap in the Text. In the Wrap Object window, under the Object tab, change the setting from Cylindrical to Spherical, and adjust the various measurements until the wireframe matches your Sphere. Then in the main menu, go to Objects > Modeling > Boole. Place the Extruded Text Wrap into the Boole.
That worked for me. Thanks, Brian, for putting me on the right path. 🙂
My only suggestion would be to save this for last, as the Boolean really slowed down further editing capabilities (by like five to ten times slower).
