Activity › Forums › Adobe After Effects › Engrave text onto a grave stone
Posted by Stig Olsen on April 22, 2015 at 1:22 pmAnyone have som good tips on how to engrave my text intro a grave stone?
Stig
Tudor “ted” jelescu replied 11 years, 4 months ago 4 Members · 3 Replies -
Michael Szalapski
April 22, 2015 at 3:14 pmBevel Alpha on a 50% grey text set to hard light.
If you do a Google search for “engrave text photoshop”, you’ll get a ton of useful tips. Those can be applied directly in After Effects or you could build it in Photoshop and use AE to place it correctly in the shot.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
John Cuevas
April 22, 2015 at 3:35 pmAndrew Kramer Procedural Crumble tutorial might be a good place to start.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Tudor “ted” jelescu
April 22, 2015 at 4:07 pmYou can use Free Form or FreeForm Pro to create a true 3d displaced text into the surface of the stone. This will enable you to play with lights to match the footage lighting.
A good tutorial with techniques that can be used:Tudor “Ted” Jelescu
Senior VFX ArtistSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
