Activity › Forums › Adobe After Effects › Endless Tunnel loop
Endless Tunnel loop
Posted by Don Johnson on August 5, 2014 at 8:25 amI am looking to create a sort of tunnel animation, as per the concentric circles in the attached file. It would be great if the response could provide an answer that would allow for them to be alternate shape/layers as well. I understand it could just be multiple layers and a camera but is that the quickest route? Perhaps someone is aware of a plugin that will repeat layers/shapes to a given infinity point?
Gary Martin replied 11 years, 1 month ago 5 Members · 5 Replies -
Tudor “ted” jelescu
August 5, 2014 at 8:48 amYou can easily create multiple instances using the Generator in FreeForm Pro or ShapeShifter AE
Tudor “Ted” Jelescu
Senior VFX Artist -
Joey Korenman
August 5, 2014 at 1:34 pmHey there! I literally just posted a tutorial on how to make awesome sci-fi space tunnels using Polar Coordinates. Check it!
Joey
Dav 02: Sci-Fi Space Tunnels with Polar Coordinates
Joey Korenman, Founder
School of Motion
Spreading Mograph Knowledge for Great Justice -
Gary Martin
July 20, 2015 at 11:35 pmHi. I saw this post and figured I’d add to it rather than start a new thread.
I’m trying to find out if there is a way to easily animate into a one point perspective grid like the one attached. and to make things more complicated, can it be in an infinite loop? And can it be done without 3rd party plugins?
i’ve scoured the forum and the internet as well and can’t seem to find what i’m looking for. Can anyone here help me?
Thank you all again.
Kalleheikki Kannisto
July 25, 2015 at 7:05 pmHi Gary,
Here’s one way to achieve it (see attached project). I used an expression which takes the index number of the layer and a slider value and scales up the layers proportionally for one loop.
(I used your sample image, replace the missing image file with that.)
To make this into an actual tunnel image (not just a grid), construct the wall, floor and ceiling pieces that are within the first complete square in your image. Just the first section in is needed. You might want some overlap over the line, my mask is not pixel-perfect. Everything’s inside a precomp, as it was better to mask off a square section.
You can remove all layers except for the control layer and the bottom one, and when all set, duplicate the bottom layer as many times an needed to get an “infinite” tunnel.
To speed up or slow down, change the comp length and move the second keyframe for the slider to the end of the comp (or actually to one frame after the end of the comp).
9083_onepointperspective.aep.zip
The expression used for the layer scale is:
transform.scale*Math.pow(1.5,index)*thisComp.layer("Control").effect("Scale")("Slider")/100Wherein 1.5 is the scale factor from one layer to the next, and there’s a Slider named “Scale” on a layer named “Control”
The slider animated from 4 to 6 (4 x 1.5 = 6, same as the scale factor between layers, for one full loop)
Gary Martin
July 26, 2015 at 2:34 pmwow! sounds like you went to a lot of trouble for this. thank you so much.
unfortunately, for the time being i am working in AFX CS6 and can’t open the file.
it sounds terrific though.
thanks again.M
