Activity Forums Apple Final Cut Pro Legacy endless ripple delete
  • endless ripple delete
    Posted by K Hendrickson on October 14, 2005 at 7:52 pm
    I’m running FCP 4.5 on a dual 1.8 G5 and every time I highlight a clip and hit the backward delete key I get a ripple delete instead. This should only happen when hitting shift + delete, or hitting the forward delete, right? Trashed prefs many times, copied and pasted into new timelines many times. Am I caught in some ripple delete mode that I don’t know about?
    Kris
    K Hendrickson replied 20 years, 11 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    October 15, 2005 at 12:33 am
    The forward delete key will always ripple delete (the one with the little x on it right?). You have it backwards I think.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Bouncing Account needs new email address
    October 15, 2005 at 11:23 am
    Yes, there are two delete keys on the keyboard.
    The “delete” key to the right of the +/= key will NON-Ripple delete (if you don’t hold down the shift key).
    The “del” key with the x inside the arrow (below the “help” key) will always Ripple delete (if that edit is “allowed” by FCP.
  • K Hendrickson
    October 15, 2005 at 3:43 pm
    So, there is no reason you know of why my delete key would be fuctioning as a ripple delete?
    Kris
    October 15, 2005 at 10:15 pm
    [k hendrickson] “So, there is no reason you know of why my delete key would be fuctioning as a ripple delete?”
    Stuck “shift” key?
    Re-programmed (re-mapped) keyboard?
  • K Hendrickson
    October 16, 2005 at 8:55 pm
    I checked the keyboard mapping and all looks correct. I think I have a buggy project file on my hands.
    Kris
