Activity Forums Adobe Encore DVD End of stream has been reached Error message
  • End of stream has been reached Error message
    Posted by Mohamed Alami on May 26, 2008 at 7:33 am
    I’m using Encore CS3, my project containing video clips and slide show’s, while building the project and after an hour, i received this Error message ” End of stream has been reached”….
    what does it mean, where i have wrong?
    many thanks
    Mohamed
    Moe
    Steve Hix replied 14 years, 4 months ago 3 Members · 2 Replies
  • Richie Finch
    July 5, 2011 at 12:14 pm
    I have the same problem Moe !
    did You sort it ???
    Rich
  • Steve Hix
    April 27, 2012 at 12:46 pm
    I had a working project (2 timelines, 2 menus, 1 slide show). I rearranged the order of some slides, then got a “Stream Overlay” error.
    I unchecked ‘Fit slideshow to audio duration’ then rechecked it to recalculate the duration (I guess… that fixed a different problem earlier). Now I’m getting “End of stream has been reached”. All due to changing order of slides in a slide show, I also resized one slide, the same way I have earlier with no problems.
    Does this help with a possible solution?
