Activity › Forums › Avid Media Composer › End of file reached
  • End of file reached
    Posted by Willstuck on June 1, 2007 at 6:50 am
    “End of file reached”
    I have this message pop up at the moment my sequence is playing and the timeline stops.
    ..using Avid Express Pro HD on a pc – all working great till now:
    3.2Gig processor, 2 gigs ram, new sata drives, nvidia graphics
    soundblaster audio…but this is the first weirdness in over a year of operation!!!
    When I turn off all video tracks, the problem does not appear. Getting rid of the clip at the point where things stop doesn’t keep the timeline from freezing.
    Googling the problem led to several comments regarding corrupted clips, (and removing pre-computes which I have removed with the Media Tool); but the problem persists.
    Avid mentions the problem with corrupted clips very briefly, but how do you find corrupted clips? One at a time, remove then check; doesn’t seem to work.
    Hoping there is an Avid Genie out there somewhere.
    wills
    John Pale replied 19 years, 3 months ago 4 Members · 3 Replies
  • Michael Phillips
    June 1, 2007 at 9:36 am
    Do a conquer and divide approach. Cut the timeline in half, then play, then again, and play till you find the piece or pieces that are corrupted. From there, do a “find clip” and recapture.
    Michael
    anything 24fps
  • Jon Zanone
    June 1, 2007 at 10:22 am
    Also, a quick way of finding corrupted files is to go into your media drives via the finder/desktop, and sort the files by name. Isolate the files with a ‘+’ at the beginning. I usually drag them outside the omf folder, keeping it on the drive. You can scroll through your timeline and see whats offline.
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • John Pale
    June 2, 2007 at 4:29 pm
    Does this happen in a specific area of the timeline, or does the sequence not play at all?
    When this has happened to me, I just made a video mixdown of the problem segment and replaced the video with it. Sometimes you don’t have the time to debug it.
