Activity Forums Adobe Premiere Pro End of File Error
  • End of File Error
    Posted by John Stevenson on April 25, 2005 at 10:56 pm
    I have a small project I need to burn to DVD, maybe 3 minutes tops. Burned to DVD right off the timeline and it transcoded fine, but at the end of the “burn” stage, the disc ejected with an “end of file” error message. The DVD plays and shows all video except the last 10-15 seconds. Then, instead of burning from the timeline, I rendered the project as a single .avi file, opened it as a new project and tried again with the same results. Changed the encoding parameters, and got the same results: “end of file” error. One would think there’s something wrong with the last portion of the video itself, but it plays off the timeline without any problem, and transcodes without error (seemingly). Ran the single .avi file through anothr burning program and it worked fine, so problem seems to be with PPro. Any ideas?
    John
    NTSC 30fps drop-frame timecode,
    Export settings (tried various bitrate presets)
    Codec: MainConcept MPEG Video
    Quality: 2.1 (low quality)
    TV Standard: NTSC
    Frame Rate [fps]: 29.97 drop frame
    Field Order: Lower
    Aspect Ratio: 16:9
    Frame Width [pixels]: 720
    Frame Height [pixels]: 480
    Bitrate Encoding: VBR, 2 Pass
    Minimum Bitrate [Mbps]: 3.8250 (low quality)
    Target Bitrate [Mbps]: 6.0000 (medium quality)
    Maximum Bitrate [Mbps]: 8.0000 (high quality)
    M Frames: 3
    N Frames: 15
    Audio Summary:
    Audio Format: PCM
    Codec: PCM Audio
    Sample Size: 16 bit
    Frequency: 48 kHz
    Have had no problems on other, even larger projects. Burning to Sony DRU-530A External burner.
    John Stevenson replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
