Activity › Forums › Apple Final Cut Pro Legacy › End Credits – creating problems in DVD Player
  • End Credits – creating problems in DVD Player
    Posted by Sridhar Kumar on July 31, 2013 at 8:38 pm
    I edited my 20 minutes short film in FCP. Subtitles are also created in FCP. For end credits, I used Adobe After Effects, exported as a mov file and imported that file into FCP. I designed my DVD in DVD SP. I tested the DVD before burning and everything looked good including the end credits. Then I burned the DVD and tested in DVD player. That’s when I came across this problem.
    Subtitles came out fine but the end credits that I created from AE is slightly blurry. I don’t where the problem is. I am assuming it might be the frame rate.
    My film in FCP is 24 fps. So when I exported the end credits file from AE, I used the same frame rate 24 fps. I used the Compressor ‘Create DVD’ template. This automatically set the frame rate to 23.98 (Inspector – Video Format – Frame Rate). I tried to change to 24 but the field is grayed out.
    When I imported the compressed ac3 and m2v files to DVDSP, I noticed that MPEG-2 Video frame rate is displaying as 29.97 fps. As I did not change the frame rate myself in Compressor/DVDSP, I did not give that much importance.
    I burned the DVD and tested in MAC which played fine. The problem occurred when I played in DVD player. Where is the problem and how do I fix this?
    PS: 1) The end credits I have is not a scrolling credit. Static credits fading in and fading out.
    2) I used the font ‘Trajan Pro’ in AE to create end credits. Can the blurry be due to this font type?
    Thanks.
    Sridhar Kumar replied 13 years, 1 month ago 2 Members · 4 Replies
  • Rafael Amador
    August 1, 2013 at 9:12 am
    [Sridhar Kumar] “My film in FCP is 24 fps.”
    Film cameras makes real 24fps.
    Video cameras make 23,98 fps which is normally called p24.
    24 fps is not a standard in video and so, DVDs are 23,98 (or 29,97).
    You must make your AE credits at 23,98fps.
    rafael
  • Sridhar Kumar
    August 1, 2013 at 10:07 pm
    I exported the credits in 23.976 frame rate from AE. Still it creates the same problem when I play it in the DVD player.
    I also tried exporting in 29.97 frame rate. Same problem.
    Even in small indie movies, I have seen clean credits without any blurry. Any one any suggestions?
  • Rafael Amador
    August 2, 2013 at 1:56 pm
    Which codec are you using?
    rafael
  • Sridhar Kumar
    August 2, 2013 at 10:50 pm
    In FCP,
    Video settings is Apple ProRes 422 (HQ).
    In Compressor,
    Video codec is MPEG-2.
    Video encoder format is M2V.
    Audio encoder format is AC3.
    Other information regarding the Video in Compressor:
    Name: DVD MPEG-2 Video, High quality Description: Maximize bit rate for duration of source File Extension: m2v Estimated size: 3.52 GB/hour of source Type: MPEG-2 video elementary stream
    Usage:SD DVD Video Encoder
    Format: M2V Width and Height: Automatic
    Selected: 720 x 480 Pixel aspect ratio: NTSC CCIR 601/DV (16:9) Crop: None Padding: None Frame rate: (100% of source)
    Selected: 23.976 Frame Controls Automatically selected:
    Retiming: (Fast) Nearest Frame Resize Filter: Linear Filter Deinterlace Filter: Fast (Line Averaging) Adaptive Details: On
    Antialias: 0 Detail Level: 0 Field Output: Same as Source
    Start timecode from source Aspect ratio: Automatic
    Selected 16:9 Field dominance: Automatic:
    Selected Progressive Average bit rate automatic,
    selected: 7.826087 (Mbps) 2 Pass VBR enabled
    Maximum bit rate: 9 (Mbps) High quality
    Better motion estimation Closed GOP Size: 15, Structure: IBBP DVD Studio Pro meta-data enabled
