Activity Forums Adobe Encore DVD End Action = Return to Loop Point
  • End Action = Return to Loop Point
    Posted by Gwendle Murray on September 29, 2008 at 11:33 am
    Ok, so I am creating an interactive dvd with many menus where the user selects certain options that take them to different videos. Each of my menus has a motion introduction whereby the buttons become active once the menu reaches the loop point I have set. My problem is, once a video has finished playing and I set the end action to go back to a certain menu, it does so but plays the menu from the very beginning, introduction and all. What I would like it to do is to return to the menu but play from the set loop point so that the buttons are available straight away and the user doesn’t have to watch the same introduction again. I thought Encore would have an option for this but I can’t seem to find it.
    How can I do this? I figure the only work around at the moment is to split the current menu at the loop point and instead have the introduction play as a timeline that at the end goes straight to the menu with the buttons active. The problem with this is I get ‘the black pause’ between the them, I want to avoid this if at all possible seeing as I’ll have an audio stutter as well.
    Any ideas?
    Joe Bowden replied 17 years, 11 months ago 3 Members · 3 Replies
  • Jeff Bellune
    September 29, 2008 at 11:59 am
    CS3 and earlier versions do not have that capability – duplicate menus must be used.
    En CS4 does have a new menu loop point feature where you choose the point at which you want the menu to start playing after it loops.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Gwendle Murray
    September 30, 2008 at 1:33 am
    Awww I need to hand this dvd in within the next two weeks! I wish they released it now!!!
    Does anyone else know of any other work arounds??
  • Joe Bowden
    September 30, 2008 at 1:43 pm
    Yes, use two menus…one that has all the animation, and the other that has only what you want.
