Activity Forums Adobe Encore DVD End Action of the timeline’s not working right.
  • End Action of the timeline’s not working right.
    Posted by Carlos Rocha on January 30, 2012 at 11:05 pm
    I have three menus:
    1) Main menu -> Play the scenes in sequence from 1 to 13
    2) Scene 1 Menu -> Play the separate scenes (1 to 6)
    3) Menu Scene 2 -> Play the separate scenes (from 7 to 12)
    13 The scene is just a clip of photos, and decided not to create a scene button on the menu for her.
    Well, here’s a screen of the properties of Scene 1.
    What happens is this:
    When the main menu (second screenshot below), I clik Movie, scene1 begins to play, when you finish goes to Scene 2, and so on. That is because I reset the EndAction’s of each chapter for the first timein the next scene. However, when one moves from scene to scene 2, there is a blank (black screen) of about 1 second. This happens in all passages from the scene.
    Daniel Ludwig replied 14 years, 8 months ago 2 Members · 2 Replies
  • Carlos Rocha
    January 31, 2012 at 11:36 am
    Nobody reply-me?
  • Daniel Ludwig
    January 31, 2012 at 4:41 pm
    hi carlos,
    the screenshots you attached to your quote are very small, so no one could see anything.
    as far as I understood your problem, you don´t want to have the black frames between sceen 1 and sceen 2.
    to me it appears you´ve set end-actions to every chapter, to get to the next one. in that reason you´ll have a short black between every chapter because of navigation commands in the deeper DVD-structure.
    I would advice to organise this project in a different way.
    1. you´ve got the “play all”-feature from chapter 1 to the end.
    2. you need to create stories for the other 2 play-option (chapter 1-6 and 7-end)
    this should result into smoothly playback of the two selections.
    cheers
    danny
