Activity Forums Adobe Encore DVD EncoreCS3 Subtitling problems
  • EncoreCS3 Subtitling problems
    Posted by Kevin Gilmour on February 24, 2009 at 4:17 pm
    Hi everyone,
    I’m creating a DVD project in Encore CS3, it is a revision of a previous project so I simply reconnected the media and made the subtitling alts by hand in Encore. The subtitles were originally imported from a text file.
    When I burn the disc however the old text is still in place. The timings have been changed, but not the text. Weird.
    Anyone have any ideas?
    I was thinking there may be a cache or something but I can’t find it.
    Cheers
    Kev G
    Kevin Gilmour replied 17 years, 6 months ago 2 Members · 2 Replies
  • Jeff Bellune
    February 24, 2009 at 5:03 pm
    1. Select all your subtitles
    2. Adjust the kerning
    3. Undo
    4. Build
    That should fix it. Test on an RW disc so you don’t get any coasters.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Kevin Gilmour
    February 25, 2009 at 1:35 pm
    Thanks Jeff, this sort of worked!
    When I changed the kerning and burned a disc it didn’t work. So I went back and burned an Image, sent it to another machine, burned it there and it worked!
    For some reason if you burn the disc directly from Encore (or create a DVD Folder) it doesn’t pick up the changes but if you export an Image file, it does.
    Weirdest problem ever.
    Kev G
