Activity › Forums › Adobe Encore DVD › Encore won’t open (shuts down or doesn’t respond)
  • Encore won’t open (shuts down or doesn’t respond)
    Posted by Yossi Siegel on September 14, 2009 at 1:46 am
    I’m trying to make a DVD (has to be made by tomorrow morning), but every time I open up Encore and select “new project” then press “OK”, a few seconds after it starts to load the entire program simply closes. I tried to open a project instead, but it stops responding.
    ADD:
    I just tried to open the program again, in order to try and set the path for the new project to my documents rather than an external harddrive, and now I can’t even open up the program! (as it loads it closes).
    Yossi Siegel replied 17 years ago 2 Members · 3 Replies
  • Yossi Siegel
    September 14, 2009 at 4:08 am
    NEVER MIND I have it all figured out!
  • Jeff Bellune
    September 14, 2009 at 11:58 am
    Please post your solution so that others may benefit from your experiences.
    Thanks.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Yossi Siegel
    September 15, 2009 at 2:04 am
    I opened up the setup file with the intentions of reinstalling, when there was an option (on the installation menu) to install codecs, which I was missing, apparently (even though it worked before).
    So DON’T FORGET YOUR CODECS PEOPLES!
