Activity › Forums › Adobe Encore DVD › Encore transcoding question….
Posted by Accountneedsrealnameupdate on August 13, 2006 at 8:20 pmI have about 3 hours of video that I used encore to burn to a 4.7GB DVD. So I assume when it trancoded it, it compressed it alot and lost alot of quality to fit on a 4.7GB DVD. So when I do my final burn on a 8.whatever gig dual layer DVD, how do I get that original quality back? Do I have to manually re-transcode all the files? It is best to let encore automatically choose the transcode settings or should I set them manually and to what?
Accountneedsrealnameupdate replied 20 years, 1 month ago 3 Members · 8 Replies -
Jeff Bellune
August 13, 2006 at 8:34 pmRight-click the asset in the Project panel and choose Revert to Original, or select the asset and choose File>Transcode>Revert to Original.
If you leave the transcode setting at Automatic, you will get better quality video when the asset is transcoded in a DL project.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
August 13, 2006 at 9:25 pmSo when I revert to original and re-transcode will encore delete or overwrite the old transcode files (not the original AVIs but whatever files it creates)? Or will I then have two sets of files?
Jeff Bellune
August 13, 2006 at 9:59 pm -
Jeff Bellune
August 13, 2006 at 11:06 pmTested in Encore 2.0: If you revert, then save your project and close Encore, the old transcode files will be gone.
Neil Wilkes
August 14, 2006 at 6:28 pmBut to be absolutely certain of no corruption, before you close out go to Edit/Preferences and then to the Audio/Video out section, and clean the media cache database.
If you’re feeling truly paranoid, delete it.
Encore will rebuild next time you open the saved project.Be careful with your layer breaks.
August 15, 2006 at 12:41 amOk, so I did the Revert to Original on all previously transcoded files. I am now in the process of transcoding and burning to a 8.5GB dual layer disc. However Encore says “Data Written: 0.00kb of 4.38GB. Why is it saying the file size tota 4.38GB? I have about 3 hours of video on thi projct and my blank disc is over 8GB. Shouldn’t it be near 8GB? It hasn’t finished, so I don’t know what the final say is. But it looks like it thinks its a 4.38GB regular dvd. Even though right above that it identifies the available media as 7.96GB. Why is it doing this?
Jeff Bellune
August 15, 2006 at 12:55 amThis is a silly question, but it has to be asked: Did you change your project settings to “8.54 GB dual layer”?
-Jeff
August 15, 2006 at 1:05 amThat was probably it. I though it would do that automatically. I changed it now, but I have a HUGE problem now. It won’t let me save the project and has an ‘unidentifiable error’ when I do. Did this before when trying to open a project and I had to start from scratch. This is not looking good. I’m gonna post a new topic on this with more info.
