Activity › Forums › Adobe Encore DVD › Encore transcoding a large file
  • Encore transcoding a large file
    Posted by James Terez on September 5, 2010 at 6:09 am
    Hi to all, I’m using encore cs5, I’m importing a timeline with 2 hours of video into encore and when I transcode I get a 7 gb file, I’m going to burn it into a dual layer disc 8.54 gb, but the problem is that I have menu and some other stuff to put in the disc too. I’m using the transcoding default setting, if there any way to transcode those 2 hours of video to a smaller file without losing quality? Thanks on advance
    Jon Geddes replied 16 years ago 2 Members · 1 Reply
  • Jon Geddes
    September 6, 2010 at 4:24 am
    You can use manual transcode settings for the video, or you can encode in the Adobe Media Encoder prior to importing into Encore.
    Also, had you imported your menus and linked everything up prior to transcoding your video in Encore, it should properly calculate the amount of space the menu will take up, and encode accordingly to fit everything.
    Jon Geddes
    http://www.precomposed.com
