Activity › Forums › Adobe Encore DVD › Encore support for 5.1 surround
  • Encore support for 5.1 surround
    Posted by Deadittex on March 14, 2006 at 5:47 pm
    Our client has requested the the DVD’s for their film have a 5.1 surround sound support. I nocie that I can acheive enough audio treacks to lay it in the audio on enough channels to do this… but what is the process so that the disk will indead support 5.1 surround? Thanks… I am using Encore 1.5 at this time.
    Is this possable and how?
    ‘The wheel weaves’
    Mylenium replied 20 years, 6 months ago 3 Members · 4 Replies
  • Mylenium
    March 14, 2006 at 6:23 pm
    You need to encode your audio file accordingly using the options provided e.g. in Audition. This has very little to do with the authoring itself -even in 5.1 you always only have one audio track per language, but that track contains multiple channels.
    Mylenium
    [Pour Myl
  • Deadittex
    March 14, 2006 at 6:38 pm
    thanks.
  • Dave Friend
    March 14, 2006 at 8:28 pm
    [Mylenium] “You need to encode your audio file accordingly using the options provided e.g. in Audition.”
    Audition will handle creating a 5.1 mix and exporting this mix in a couple of different ways. Unfortunately Encore will not be able to use any of these exports directly. The first issue is that Encore only encodes stereo ac3 (dolby) files. Secondly, it will not open a multichannel file that you could create with Audition.
    You need other software (or hardware) to encode a surround sound dolby file.
    Adobe Premiere Pro (with an optional plug-in) can create and export surround sound encodes that can be used by Encore. You could also probably accomplish the 5.1 mix with Premiere Pro but might find Audition to be better suited to the task. The Audition exports would be used by PPro to encode the dolby file to be used by Encore.
    Creating surround sound mixes is probably a career unto itself. Expect to spend a lot of time climbing the learning curve before you get useable product – or hire an expert.
    Dave
  • Mylenium
    March 15, 2006 at 6:41 am
    I didn’t know that. I don’t use Audition nor Premiere. We have scenarist here which can easily encode surround files or we get them from external service providers because, as you said so nicely, it’s an art in itself to create a good audio mix (even for “just stereo”).
    Mylenium
    [Pour Myl
