Activity Forums Adobe Encore DVD encore subtitle too complex
  • encore subtitle too complex
    Posted by Dagi Vujacic on December 18, 2006 at 10:24 pm
    Well. After finishing everything and subtitling the movie one hour and twenty minutes long I tryed to export it to dvd. After a some proces of transcoding it stoped showing this mesage – The subtitle or menu subpictures are too complex to be encoded? So I am stucked with it. Enyone can help?
    Annietron replied 19 years, 8 months ago 4 Members · 19 Replies
  • 19 Replies
  • Mike Velte
    December 19, 2006 at 6:34 pm
    Make sure you have no subpictures (buttons) overlapping on your menus.
  • Dagi Vujacic
    December 20, 2006 at 2:04 pm
    definetly not
  • Joe Bowden
    December 20, 2006 at 2:38 pm
    Have you got any subtitles?
  • Dagi Vujacic
    December 20, 2006 at 3:30 pm
    I created subtitles for a one-hour and a 20 min long movie (I typed it on a screen all on one subtitles layer). It all looks fine at preview. I arrange their position and length. Make them Arial font and so. Now each time when I tried to build a DVD (to disc or to folder) It starts transcoding audio – first, than subtitles, and after a while bumped on me with – CREATING SUBTITLES FAILED … The SUBTITLE OR MENU SUBPISTURE IS E TO COMPLEX TO BE ENCODED!? I did not create any meny since I like this movie, to start immediately if it s’ corect.
  • Joe Bowden
    December 20, 2006 at 4:16 pm
    Try using fewer characters per subtitle- split them up if necessary- and see if that helps.
  • Dagi Vujacic
    December 20, 2006 at 6:50 pm
    Sommeone adviced me to export subtitles in some known forma and then to import it again – like – it might help, but I have no idea how to export subtitles from Encore.
  • Joe Bowden
    December 20, 2006 at 8:09 pm
    Encore cannot export subtitles (except via burning to DVD).
  • Dagi Vujacic
    December 20, 2006 at 9:09 pm
    So if I burn it to DVD folder, for what file should I looking for and what to do with it. Can I be able to import this in to , for example, Subtitle workshop?
  • Joe Bowden
    December 20, 2006 at 9:21 pm
    You could strip the streams out with DVD Decrypter or another app, but I believe the subtitles are a bitmap stream (you wouldn’t be able to edit them), but I am not positive of that.
  • Dagi Vujacic
    December 20, 2006 at 9:58 pm
    Thanks Joe. I’ll try to rip it with a Subrip. Hope it ‘ll help.
