Encore skipping an asset
Hey guys,
I have a small problem I need help with. What I am doing is having my opening animation go straight into my main menu which has a background animation. So what I did was create two black menus, put the opening animation in menu #1 and the menu animation in menu #2… using the “motion menu” for both (note that the opening and menu animation are 2 halves of the same long animation). The end action of menu #1 is that it would play menu #2, so when someone presses a button and comes back to the main menu, they don’t have to go through the opening animation again. The problem is, after I built the file to a folder so I could test it, as soon as the file opens, it goes straight to the menu animation, and completely bypasses the opening animation.
Any suggestions??
Thanks in advance…
Stephen
