Activity Forums Adobe Encore DVD ENCORE Saving and Applying Button Properties
  • ENCORE Saving and Applying Button Properties
    Posted by Richard Hutt on March 28, 2011 at 4:07 pm
    Hi
    In Encore, I have imported as Assets, pictures that I use as Buttons for Chapters on my DVD. I have to re-size each one and add a shadow each time I do this. Is there a way that I can save the properties of buttons that i have created and apply them to new buttons as I make new DVD menus from my template master or am I forever subjected to manually adjusting them each week?
    Ricahrd
    Richard Hutt replied 15 years, 5 months ago 3 Members · 4 Replies
  • Jeff Bellune
    March 28, 2011 at 5:37 pm
    Make sure both the Library panel and the Menu Viewer are open and accessible. Drag your button from the menu to the Library. En will ask you to name the new Library asset. Once you name it, it will always be available in the Library for future use.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Richard Hutt
    March 28, 2011 at 7:57 pm
    Jeff
    Thanks for the idea, but before I try this, let me further explain myself. Each week i will have a new DVD to make with 3 new segments. Each week i will have to create 3 new pictures of guests from the show and use them in the Menu. Is there a way that I can save just the attributes from the previous week and apply them to the new pics so they all resize the same. (Much like CTRL C -copy and CTRL V paste when working in graphic editing.) I am tryingt o not have to manually resize each picture when i bring it into Encore.
    I hope this explains it better
    and thanks for your help so far
    Richard hutt
    City of Chesapeake VA
    Public Communications dept.
  • John Rich
    March 29, 2011 at 11:46 pm
    This might be a good application of “Replacement Layers”.
    You could make the menu with several replacement layers and then each week import the menu and your new stills and drag the stills into replacement layers.
    John Rich
    JOHNR
  • Richard Hutt
    March 30, 2011 at 12:04 pm
    Cool I will see how this works thanks for the tip.
    Richard
