Activity › Forums › Adobe Encore DVD › Encore replacement software that can create flexible menus for blu-ray discs
Posted by Doug Sowerby on March 5, 2020 at 9:11 pmMy hard drive failed and I lost Adobe Encore which Adobe will not help with retrieving because I now have CC. I need a new flexible menu creator for blu-ray discs. Any help is appreciated. Thanks in advance
Doug Sowerby replied 6 years, 6 months ago 3 Members · 4 Replies -
Eric Santiago
March 6, 2020 at 7:33 pmFlexible menu creator?
As in a new Blu-ray authoring app?
Cheap and simple would be Toast. -
Doug Sowerby
March 6, 2020 at 7:48 pmYes, a Blu-ray authoring app, and thank you for your suggestion. I will definitely look into Toast.
Cheap is nice, but I’m fine with a more professional option as well.
Thanks again. -
Stan Jones
March 7, 2020 at 1:05 pmJust FYI. If you were using Encore solely because you had a subscription, then yes, no option. If you originally purchased Encore as part of CS6, you may still be able to use it.
Having your original boxed set helps. Having a download from a third party seller may work.
Log in to your Adobe account. Find your registered products. If you have a CS6 license, note the number. Contact customer support. If you bought the download product from Adobe, they may provide a link to the necessary files.
Stan Jones
Doug Sowerby
March 8, 2020 at 4:05 pmI had explained to Adobe that I got Encore when I first downloaded Creative Cloud back in 2012. It came with that version of Adobe Premier. Unfortunately, according to Adobe, it’s now only available via CS6 which is a different license from Creative Cloud. Not sure how that works, but basically they can’t give me CS6 because of licensing. I asked for a CC legacy version of Premier that would still contain Encore, but they don’t have any versions that old. I personally find that hard to believe. I don’t understand why Adobe would just discard Encore like that with so many people using it. Anyway, sorry for the rant. Thank you so much for your help, I appreciate your time and any further suggestions. Cheers!
