Activity Forums Adobe Encore DVD encore on mac giving a windows error????
  • encore on mac giving a windows error????
    Posted by Twann Hudson on September 22, 2008 at 9:53 pm
    i have created a project on a mac 4 core a few weeks ago using encore i sent it out using the flash option – now two weeks later I’m trying to make another flash file . i have not changed anything nor moved and files around – but it’s giving me the error that –
    this project was created on a windows platform and can not be opened on the mac!
    what can cause this ?
    the real fun begins when the program loads
    running FCS & CS3 MS side by side on the Mac
    Matthew Harnick replied 16 years, 8 months ago 4 Members · 3 Replies
  • Ben Holmes
    September 27, 2008 at 11:13 pm
    Bad software. Have a search below for the same issue. It’s just buggy, awful software. Sorry about that.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • Jordi J recort
    November 11, 2008 at 1:15 pm
    I found a solution..
    as stupid as the problem is!!!!
    Maybe will not be suitable for everyone, but it works if you have both computers on the same network.
    1. copy all the assets to the second mac (as you will do anyway)
    2. From Mac 2, connect to Mac 1 and remotely open the project from Mac 1
    3. The project will open on Mac 2 and will ask to reconnect media
    4. Reconnect media to the local folder on Mac 2
    5. Save as the project on local hard disck on Mac 2 and you’re ready to rock!
    Stupid workarounds for stupid problems!
    Cheers!
    Jordi J. Recort
    Encamp/Andorra
    Jordi J. Recort
    Composer & Editor
  • Matthew Harnick
    December 29, 2009 at 9:42 pm
    I can’t say this will be the issue each time, but I’ve been getting this issue for ages, and somehow it finally dawned on me what happened, in this scenario at least.
    I was consolidating a couple of project folders into a larger one, and moved the .ncor file as well. I had just been working with this project, and had just saved it right before I moved the .ncor file, so I knew it was something simple. All I did was move the .ncor file back to where it was previously located, and it worked fine.
    Again – I’m not suggesting that this is the only reason this error would occur, but in my case it was a two-second fix and the right fix. Moral of the story, don’t move anything until it’s done. Good luck.
