Activity › Forums › Adobe Encore DVD › Encore on CD
Encore on CD
Posted by Brian Holson on May 5, 2010 at 8:36 pmIs it possible to make a slideshow in Encore and put it on a CD instead of a DVD?
Mike Cohen replied 16 years, 4 months ago 4 Members · 6 Replies -
Eric Pautsch
May 6, 2010 at 4:45 amOK…I’ll bite! Why would you want to do that? DVD players play DVDs 🙂
Brian Holson
May 6, 2010 at 12:23 pmSorry, I should have explained better. Can an Encore slideshow be put on a CD?
Clint Milner
May 6, 2010 at 1:57 pmYou can export your Encore project as Flash, and then if it’s small enough, burn all the files to disc.
Clint
Adobe CS4 Master Suite
Vista Ultimate 64 SP1
Intel Core i7 920 @ 3.60GHz
12 GB DDR3 RAM
NVidia Quadro FX 3700
Matrox RT.X2 LE Capture Card
4 TB RAID 5 -
Eric Pautsch
May 7, 2010 at 12:50 amWell you might as well use Flash then. Besides there are tons of bugs in the Flash Converter. Encore is a DVD Authoring tool made for DVDs so No, you can put a DVD project on a CD. 🙂
Brian Holson
May 7, 2010 at 12:33 pmThanks Guys, I assumed that was the answer but I thought maybe someone had a trick of how to do it.
I appreciate you taking the time to answer my question! 🙂
Mike Cohen
May 7, 2010 at 5:58 pmThere are many, some free, slideshow makers – the end result of most is Flash, which can be embedded in a html document, and put on CD easily enough.
What is your application?
Mike Cohen
