Activity Forums Adobe Encore DVD Encore Menu “Selection”
  • Encore Menu “Selection”
    Posted by Erik Carlson on July 2, 2010 at 9:18 pm
    So I don’t know if this is possible in Encore or at all even. I have a menu “jukebox”. There are buttons linked to each song selection. Is it possible to have the selection prefix be an actual image or does it just work as a solid color?
    Basically I have a round button that “sticks out” and I would like for when the user selects that option the button is then “pushed in”.
    If that sounds confusing
    John Rich replied 16 years, 2 months ago 2 Members · 1 Reply
  • John Rich
    July 7, 2010 at 12:43 am
    I’ve never done this, so this is just an idea and is pretty complex. It requires a 3d type program which in this case would be Zaxwerks Invigorator Pro. You’d also have to be able to use Illustrator.
    https://library.creativecow.net/articles/hamad_serge/depth_scale/video-tutorial.php
    This creates compression of the button.
    Then you’d use the render of the button compressing and go to Andrew Kramer’s tutorial here.
    https://videocopilot.net/tutorials/dynamic_bar_graphs/.
    You would make a short clip for each button compressing and then put it into Encore as a button transition for each button.
    It might be tough to line up the menu button with the moving button.
    Just some thoughts.
    John Rich
    JOHNR
