Activity Forums Adobe Encore DVD Encore Media Cache?
  • Encore Media Cache?
    Posted by Vin Alsace on December 21, 2011 at 4:03 am
    System: Windows 7
    Encore CS5
    I have an encore project that in a previous saved version had a subtitle track turned on as a default. In the disc properties, I had “Set Subtitle: 1”. “1” was my subtitle track. This worked fine and I created .iso files with this that worked correctly.
    I wanted a version where the subtitles were turned off as the default, so I “Set Subtitle: Off” in the Disc Properties. I saved the encore file, went into Edit > Preferences > Media: Delete Media Cache.
    I checked the project. There were no errors. I built the ISO again. When I mounted the iso on Virtual Clone Drive to test it, this new version still has the subtitles set to “on” as the default.
    I wasn’t even sure this was a media cache issue, but thought it might be. Does anyone know what could be causing these subtitles to continue to be turned on as a disc property, even though I have them turned off?
    Vin Alsace replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
