Activity Forums Adobe Encore DVD Encore Language not changing
  • Encore Language not changing
    Posted by Nancy L. sutton smith on July 24, 2011 at 6:14 am
    I apologize for this newb question, but I just can’t seem to understand the translation function in Adobe Encore. When I Add a Subtitle Track, I can change the language to – say French, type in English and it should come out translated on the DVD? If that’s the case it isn’t working. Does my WinDVD have a French option? It doesn’t make sense to me that if I have to type in French in a text script and import it, then why is that language pull down menu there on the subtitle track. See, I told you it was a newb question. I just tried it on my TV and the French track came out in English. Thank you for your help!
    Nancy L. Smith
    President
    Sutton Bay Media Company
    Daniel Ludwig replied 15 years, 1 month ago 2 Members · 3 Replies
  • Daniel Ludwig
    July 26, 2011 at 9:47 pm
    hi nancy,
    you need to have a translated text within your subtitle-track. there is no automatisation for translation within any authoring-tool.
    you need to give your subtitle to a translation service so you can get another file back for the other language(s).
    cheers
    danny
  • Nancy L. sutton smith
    August 1, 2011 at 2:42 pm
    Thank you Danny! I began to realize that the more I read. So my question is still – why is that pull down menu there to the left in the track? I think it is a label for the DVD player and TV – so if you are using Dutch – the menu button says “Dutch”. Is that correct?
    Nancy L. Smith
    President
  • Daniel Ludwig
    August 1, 2011 at 8:35 pm
    Nancy,
    the subtitle-ID is nothing that has to do with menu-navigation or something else.
    It´s just an ID you´ll see, if you will use the subtitle-button on your remote-control. if you skip through the subtitle you´ll see the ID of each subtitle-stream.
    that´s it – a simple use-responce to show the user which subtitle-stream he/she is using.
    cheers
    danny
