Activity Forums Adobe Encore DVD Encore .ISO
  • Encore .ISO
    Posted by Kslocum on May 31, 2005 at 3:57 pm
    Can you make an .ISO file out of an Encore project? If not is there a utility or application that can do the conversion? The company I work with needs an .ISO file so I’m stuck unless I find a away to do this. Thanks.
    Brian Deviteri replied 21 years, 3 months ago 3 Members · 3 Replies
  • Victorypoint
    May 31, 2005 at 4:44 pm
    I think you just rename the Encore image file to an ISO extension. This works when I burn the ISO file to DVD with Nero.
    -AJ
  • Kslocum
    May 31, 2005 at 4:48 pm
    Thank you. I just read that on the Adobe boards as well. I’ll give it a try. I hope it’s that simple. Thanks for the prompt reply.
  • Brian Deviteri
    June 2, 2005 at 1:07 am
    It really is that easy, I do it all the time.
