Activity › Forums › Adobe Encore DVD › Encore error: Sense Code 37202
  • Encore error: Sense Code 37202
    Posted by Janus Vinther on May 27, 2011 at 8:57 am
    When I burn a normal project with a normal DVD-menu (made in Photoshop)and 2-3 movieclips,why do I sometime get this error:
    “Encore was unable to complete the operation because of a hardware error (Sense Code 37202). Please contact the hardware manufacturer for more information.”
    The project work perfectly and when I do the Check Project, everything seems to be perfect. The burning starts up normaly, but it ends up with the error-message and the DVD don’t work.
    Hope you can help me with the problem.
    // Janus.
    Janus Vinther replied 15 years, 3 months ago 2 Members · 2 Replies
  • Minu Sharma
    June 15, 2011 at 9:41 am
    Hi
    This error is hardware related error , Either your burner is not recognized by encore or you are using a bad media . Change disc , check burner connection and try again .
    Minu
  • Janus Vinther
    June 19, 2011 at 11:33 am
    Thanks. I think the problem is fixed.
    Janus Vinther
