Activity Forums Adobe Encore DVD Encore DVD CS6 does not open on Enterprise
  • Encore DVD CS6 does not open on Enterprise
    Posted by Danilo Viana on July 14, 2018 at 2:14 pm
    Hello Professionals !!!
    I have the following problem with “Encore DVD CS6”:
    I installed on my machine for a period of evaluation the Windows 10 Enterprise 2016 LTSB (I know it is for companies the OS but this is not the case), however my Encore DVD CS6 does not work, it starts loading and closes alone, someone here already Did you go through that and know how to solve it?
    The log file error is as follows:
    2018-07-14 11:11:26 [4184] AMT: START SESSION, library version 6.0.0.75,6.0
    2018-07-14 11:11:26 [4184] AMT: Initializing C:\Program Files\Adobe\Adobe Encore CS6
    2018-07-14 11:11:26 [4184] AMT: Adobe License Manager version 3.5 (build 2.0) RELEASE
    2018-07-14 11:11:26 [4184] AMT: Virtualization Turned off
    2018-07-14 11:11:26 [4184] PCDService: PCD Service in non-threaded mode
    2018-07-14 11:11:26 [4184] performance: AMTPreObtainProductLicense took 0.670334 ms
    2018-07-14 11:11:26 [4184] AMT: RW check key updated !
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [0] = pt_BR
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [1] = en_US
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [2] = en_AE
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [3] = en_GB
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [4] = en_IL
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [5] = cs_CZ
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [6] = nl_NL
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [7] = pl_PL
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [8] = ru_RU
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [9] = sv_SE
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [10] = tr_TR
    2018-07-14 11:11:26 [4184] AMT: App Product Locale [11] = zh_TW
    2018-07-14 11:11:26 [4184] config: Loading configuration for C:\Program Files\Adobe\Adobe Encore CS6\AMT\application.xml
    2018-07-14 11:11:26 [4184] config: Found payload code {46251F95-B2F8-484A-9B5B-8C0E5A43A202}
    2018-07-14 11:11:26 [4184] PCDService: found driver code {E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}
    2018-07-14 11:11:26 [4184] config: config: Host app was installed, using installed license configuration.
    2018-07-14 11:11:26 [4184] PCDService: Failed to read value for key [FLMap] in hive [EncoreApp-CS6-Win-GM{|}ALL] from cache : 769
    2018-07-14 11:11:26 [4184] config: Setting current license to the driver at startup because no mapping was found.
    2018-07-14 11:11:26 [4184] config: Setting current license to MasterCollection-CS6-Win-GM [ALL]
    2018-07-14 11:11:26 [4184] config: payload code: {46251F95-B2F8-484A-9B5B-8C0E5A43A202}
    2018-07-14 11:11:26 [4184] config: driver payload code: {E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}
    2018-07-14 11:11:26 [4184] config: driver licensing code: MasterCollection-CS6-Win-GM
    2018-07-14 11:11:26 [4184] config: current licensing code: MasterCollection-CS6-Win-GM
    2018-07-14 11:11:26 [4184] config: current locale code: ALL
    2018-07-14 11:11:26 [4184] config: Done loading configuration
    2018-07-14 11:11:26 [4184] config: Setting insalled locales
    2018-07-14 11:11:26 [4184] config: Changing locale to “en_US” because old locale “” is not in the new list of installed languages
    2018-07-14 11:11:26 [4184] AMT: Installed Locale [0] = en_US
    2018-07-14 11:11:26 [4184] AMT: Reordered Locale [0] = en_US
    2018-07-14 11:11:26 [4184] AMT: Reordered Locale [1] = en_AE
    2018-07-14 11:11:26 [4184] AMT: Reordered Locale [2] = en_GB
    2018-07-14 11:11:26 [4184] AMT: Reordered Locale [3] = en_IL
    2018-07-14 11:11:26 [4184] AMT: config: Finding license info for payload: {E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}
    2018-07-14 11:11:26 [4184] AMT: config: PayloadCode: {46251F95-B2F8-484A-9B5B-8C0E5A43A202}
    2018-07-14 11:11:26 [4184] AMT: config: Driver PayloadCode: {E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}
    2018-07-14 11:11:26 [4184] AMT: config: Installed LicensingCode: MasterCollection-CS6-Win-GM
    2018-07-14 11:11:26 [4184] PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{46251F95-B2F8-484A-9B5B-8C0E5A43A202}] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [BridgeTalkCode] in hive [{E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [ISO_TAGGING_DISABLED] in hive [EncoreApp-CS6-Win-GM] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [EULA] in hive [{E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [Registration] in hive [{E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [Registration] in hive [{46251F95-B2F8-484A-9B5B-8C0E5A43A202}] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [Growl] in hive [{E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [Growl] in hive [{46251F95-B2F8-484A-9B5B-8C0E5A43A202}] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [EULAForPassive] in hive [EncoreApp-CS6-Win-GM] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [EULAForPassive] in hive [MasterCollection-CS6-Win-GM] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [Updates] in hive [{E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [Updates] in hive [{46251F95-B2F8-484A-9B5B-8C0E5A43A202}] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [SuiteFeatureCount] in hive [MasterCollection-CS6-Win-GM] in master : 10
    2018-07-14 11:11:26 [4184] AMT: Application can be serialized (Non Passive App).
    2018-07-14 11:11:26 [4184] PCDService: Failed to read value for key [LicensedLocales] in hive [EncoreApp-CS6-Win-GM{|}LicLoc] from cache : 769
    2018-07-14 11:11:26 [4184] PCDService: Failed to read value for key [SN] in hive [MasterCollection-CS6-Win-GM{|}en_US] from cache : 769
    2018-07-14 11:11:26 [4184] config: No en_US licensed serial number found in MasterCollection-CS6-Win-GM
    2018-07-14 11:11:26 [4184] config: Enigma Data Found from SLCache
    2018-07-14 11:11:26 [4184] PCDService: Failed to read value for key [AMTConfigPath] in hive [{E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}] from cache : 769
    2018-07-14 11:11:26 [4184] PCDService: No value for key [ExpirationDate] in hive [EncoreApp-CS6-Win-GM] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [LineCV 1] in hive [MasterCollection-CS6-Win-GM{|}ALL] in cache : 519
    2018-07-14 11:11:26 [4184] PCDService: No value for key [LineCV 3] in hive [MasterCollection-CS6-Win-GM{|}ALL] in cache : 519
    2018-07-14 11:11:26 [4184] PCDService: No value for key [LineCV 4] in hive [MasterCollection-CS6-Win-GM{|}ALL] in cache : 519
    2018-07-14 11:11:26 [4184] PCDService: No value for key [LineCV 5] in hive [MasterCollection-CS6-Win-GM{|}ALL] in cache : 519
    2018-07-14 11:11:26 [4184] PCDService: No value for key [LineCV 6] in hive [MasterCollection-CS6-Win-GM{|}ALL] in cache : 519
    2018-07-14 11:11:26 [4184] PCDService: No value for key [LineCV 7] in hive [MasterCollection-CS6-Win-GM{|}ALL] in cache : 519
    2018-07-14 11:11:26 [4184] PCDService: No value for key [LineCV 2] in hive [MasterCollection-CS6-Win-GM{|}ALL] in cache : 519
    2018-07-14 11:11:26 [4184] AMT: Subsequent launch (serial [92298406649049231379]).
    2018-07-14 11:11:26 [4184] AMT: Application state initialized. Obtaining Product License.
    2018-07-14 11:11:26 [4184] AMT: Obtaining client features from cache.
    2018-07-14 11:11:26 [4184] PCDService: Failed to get feature status from hive [MasterCollection-CS6-Win-GM{|}ALL]: 770
    2018-07-14 11:11:26 [4184] AMT: Obtaining client product info from cache.
    2018-07-14 11:11:26 [4184] PCDService: No value for key [ENABLE_GUEST] in hive [MasterCollection-CS6-Win-GM] in master : 10
    2018-07-14 11:11:26 [4184] AMT: Running in PROV_APP
    2018-07-14 11:11:26 [4184] PCDService: No value for key [EULADelay] in hive [{E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}] in master : 10
    2018-07-14 11:11:26 [4184] PCDService: No value for key [MediaTag] in hive [{E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}] in master : 10
    2018-07-14 11:11:26 [4184] config: No media tag found for payload {E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}
    2018-07-14 11:11:26 [4184] config: Using default media policy RET
    2018-07-14 11:11:26 [4184] uiswitch: EULA has already been accepted.
    2018-07-14 11:11:26 [4184] AMT: This is a subsequent launch. Deferring services.
    2018-07-14 11:11:26 [4184] performance: AMTObtainProductLicense took 14.926560 ms
    2018-07-14 11:11:27 [4184] performance: AMTValidateProductLicense took 0.001201 ms
    2018-07-14 11:11:27 [4184] AMT: AMTGetParentLEIDLicenseStatus called.
    2018-07-14 11:11:27 [4184] SLCoreService: Starting up SLCore 2.0 Release (build 2.0.1.301001).
    2018-07-14 11:11:27 [4184] SLCoreService: Service construction took 0.0 ms and succeed.
    2018-07-14 11:11:27 [4184] AMT: Parent LEID not passed Relying on Licensing LEID MasterCollection-CS6-Win-GM
    2018-07-14 11:11:27 [4184] SLCoreService: Syncing to license store…
    2018-07-14 11:11:27 [4184] SLCoreService: Found client mkey.
    2018-07-14 11:11:27 [4184] SLCoreService: Loading license references…
    2018-07-14 11:11:27 [4184] SLCoreService: Found 5 license file(s)
    2018-07-14 11:11:27 [4184] SLCoreService: Parsing license file [151923421.lic] succeed.
    2018-07-14 11:11:27 [4184] SLCoreService: Parsing license file [188458141.lic] succeed.
    2018-07-14 11:11:27 [4184] SLCoreService: Parsing license file [22702493.lic] succeed.
    2018-07-14 11:11:27 [4184] SLCoreService: Parsing license file [234771805.lic] succeed.
    2018-07-14 11:11:27 [4184] SLCoreService: Parsing license file [28738525.lic] succeed.
    2018-07-14 11:11:27 [4184] SLCoreService: License store synchronization took 17.6 ms and succeed.
    2018-07-14 11:11:27 [4184] SLCoreService: Query license: type = 2, duration = permanent, remaining = permanent.
    2018-07-14 11:11:27 [4184] PCCheck: Royalty Bearing.
    2018-07-14 11:11:27 [4184] PCCheck: Protected Content.
    2018-07-14 11:11:27 [4184] PCCheck: Breaking Out!
    2018-07-14 11:11:27 [4184] AMT: Return Code 3
    2018-07-14 11:11:27 [4184] performance: AMTGetParentLEIDLicenseStatus took 17.834843 ms
    2018-07-14 11:11:27 [4184] PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}] in master : 10
    2018-07-14 11:11:27 [4184] PCDService: No value for key [AdobeUpdaterCodeV2] in hive [{46251F95-B2F8-484A-9B5B-8C0E5A43A202}] in master : 10
    2018-07-14 11:11:27 [4184] PCDService: No value for key [Updates] in hive [{E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0}] in master : 10
    2018-07-14 11:11:27 [4184] PCDService: No value for key [Updates] in hive [{46251F95-B2F8-484A-9B5B-8C0E5A43A202}] in master : 10
    2018-07-14 11:11:27 [4184] AUMService: config: No AdobeUpdaterCode found in configuration; AUM will be disabled.
    2018-07-14 11:11:27 [4184] ServiceLoader: looking for library C:\Program Files\Adobe\Adobe Encore CS6\updaternotifications.dll
    2018-07-14 11:11:27 [4184] ServiceLoader: Found library C:\Program Files\Adobe\Adobe Encore CS6\updaternotifications.dll
    2018-07-14 11:11:27 [4184] SLCoreService: Shutting down SLCore 2.0 Release (build 2.0.1.301001).
    2018-07-14 11:11:27 [4184] SLCoreService: Service destruction took 0.4 ms and succeed.
    2018-07-14 11:11:27 [4184] performance: AMTReleaseProductLicense took 0.715963 ms
    2018-07-14 11:11:27 [4184] AMT: END SESSION.
    If anyone can help me I’ll be very grateful !!!
    Danilo Viana replied 8 years, 2 months ago 3 Members · 8 Replies
  • 8 Replies
  • Stan Jones
    July 14, 2018 at 3:39 pm
    What kind of license: cloud subscription or disk install with license key?
    It is failing licensing.
    Stan Jones
  • Danilo Viana
    July 14, 2018 at 5:01 pm
    You are in the trial version 🙁
  • Stan Jones
    July 14, 2018 at 6:39 pm
    Ah, yes. There is no Encore trial. It will install with Premiere Pro, but will not run until licensed.
    Stan Jones
  • Danilo Viana
    July 16, 2018 at 6:18 pm
    I understood, I did not know about this problem.
    But can you tell me if it will work on OS Enterprise?
  • Stan Jones
    July 16, 2018 at 8:22 pm
    I do not know for enterprise. I see no reason it would not, but it is EOL (end of life) and is officially not supported on modern operating systems. But many of us use it.
    Stan Jones
  • Danilo Viana
    July 17, 2018 at 10:23 am
    Can I have trouble getting an irregular license just to test the full version to see if I buy the package or not?
  • Jan Janowski
    July 18, 2018 at 2:01 pm
    I can’t speak for W10, but a couple years ago at work I installed and ran it on W7-64 Enterprise, and it worked flawlessly there.
  • Danilo Viana
    July 18, 2018 at 2:20 pm
    Very strange this, I will check more deeply what it may be but for now thank you very much
