Activity Forums Adobe Encore DVD Encore – DVD capacity?
  • Encore – DVD capacity?
    Posted by Davidnagel on September 29, 2005 at 9:10 am
    Using Encore’s Transcode settings I’ve noticed when it comes to creating the final dvd image, the file size is considerably bigger than what the average DVD can hold.
    The video and sound is encoded to a very high quality, which is perfect, but they don’t fit on a standard dvd, especially for a standard, movie-length with bloopers and behind-the-scenes features.
    Is there something I’m missing? Are there larger DVD discs out there I can use instead of the usual 4.7gb?
    David.
    Tim Kurkoski replied 20 years, 11 months ago 3 Members · 2 Replies
  • Kermit
    September 29, 2005 at 1:52 pm
    Absolutely…there is the DVD 9 which hold about 8.5 Gig (don’t ask why it’s called a DVD 9), but you do need a burner that can burn to these disks
    Otherwise sometimes you can get double sided disks…
  • Tim Kurkoski
    September 29, 2005 at 4:26 pm
    David-
    How long is your video? It sounds like you need to customize your bitrates, which will involve doing some “bit budgeting”. Mike Velte’s site has a rough guide to what bitrates to use to fit a given amount of video on a DVD:
    https://www.video2stream.com/using_the_adobe_mpeg_encoder.htm
