Activity Forums Adobe Encore DVD Encore DVD 2.0 & Disc space
  • Encore DVD 2.0 & Disc space
    Posted by Davidnagel on March 14, 2006 at 8:53 pm
    Hiya, not your run of the mill file size issue, more of a lack of space to put file sizes!
    I have a personal copy of Adobe Encore DVD 2.0 and have recently finished a 4 gig DVD project.
    Getting to the Build panel and pressing Build begins the process, but Encore has other ideas. Encore believes that it needs to use drive D:\ which at the moment only has 1.1gb space left, but fails to see that drive F:\ has 13gbs.
    How do I tell Encore to use drive F:\ instead of drive D:\?
    General preferences fail to show any field to change the temp folder location. Is there something I’m missing?
    davidnagel
    Rich O. replied 20 years, 5 months ago 2 Members · 2 Replies
  • Davidnagel
    March 14, 2006 at 9:01 pm
    False alarm.
    It seems Encore transcodes the files on the drive the project is saved.
    Seems odd to me.
    Anyways, please would an admin/mod remove these postings?
    davidnagel
  • Rich O.
    March 15, 2006 at 5:44 pm
    David, this posting is useful. I ran into the same problem and actually copied my entire folder onto my video drive instead of where I mistakenly set it by default, my system drive. I did not see a default path either, which would allow me to always select a given drive for rendering projects. Encore on the surface resembles the other Adobe products, but things seem a little off Adobe standard when you use it. Not a bad thing, but harder to figure out in some matters.
    Rich O.
