Activity Forums Adobe Encore DVD Encore DVD 2.0 anamorphic 16:9
  • Encore DVD 2.0 anamorphic 16:9
    Posted by Anetmedia on March 7, 2007 at 8:39 pm
    Hi, I can’t import the .m2v video files that were shot and edited in anamorphic video 1064×576 PAL. The project-transcode-menu and the help-manual inform me, that Encore 2.0 only supports 720×576 Pal. Is this true? I am currently looking at the Trial Version because I need a DVD authoring software with advanced features (.ac3 5.1, subtitle import options, 16:9 high resolution). Is there an upgrade available or another product or solution?
    Best, anet
    Mylenium replied 19 years, 6 months ago 3 Members · 2 Replies
  • Jeff Bellune
    March 7, 2007 at 9:17 pm
    Anamorphic widescreen PAL video is not 1064×576. It is 720×576 with a PAR of 1.422.
    Encore can transcode PCM audio to 2-channel .ac3. It can import and export already-transcoded 5.1 .ac3 files, but you cannot transcode 5.1 .ac3 audio from inside of Encore.
    You can import several types of subtitle files into Encore from programs like Lemony and Subtitle Workshop.
    Encore has no trouble authoring high-quality 16:9 Standard Definition DVDs. If you want HD-DVD and/or Blu-Ray authoring solutions, then you must look elsewhere. Sonic Scenarist can do HD-DVD and/or BR if you purchase enough of its various components. Expect a really hefty price tag.
    HTH,
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Mylenium
    March 8, 2007 at 11:44 am
    [anetmedia]
    Hi, I can’t import the .m2v video files that were shot and edited in anamorphic video 1064×576 PAL. The project-transcode-menu and the help-manual inform me, that Encore 2.0 only supports 720×576 Pal. Is this true?”
    Incorrect resolution. 1024×756 is the square equivalent of a 16:9 widescreen video (720×576, 1.422 PAR) and only meant for compositing work 3D animation and that stuff. If you encode it directly to MPEG-II, you get an invalid stream because it isn’t compliant with the specs of the DVD (Video) format (wrong block allocation etc.). Of course everything else that Jeff said also applies.
    Mylenium
    [Pour Myl
