Activity › Forums › Adobe Encore DVD › Encore Cs6
  • Encore Cs6
    Posted by Fernando Coelho on May 9, 2013 at 12:49 am
    I have installed the version Cs6 Encore DVD and create a timeline with my project the following error:
    Process: Adobe Encore [326]
    Path: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/MacOS/Adobe Encore
    Identifier: com.adobe.Encore
    Version: 6.0.1 (6.0.1)
    Code Type: X86-64 (Native)
    Parent Process: launchd [154]
    User ID: 501
    Date/Time: 2013-05-08 21:17:17.508 -0300
    OS Version: Mac OS X 10.8.3 (12D78)
    Report Version: 10
    Interval Since Last Report: 194997 sec
    Crashes Since Last Report: 23
    Per-App Interval Since Last Report: 25633 sec
    Per-App Crashes Since Last Report: 22
    Anonymous UUID: 6D1FDF90-8050-E2F2-3D8A-D6441DFB6149
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x000000012369aa80
    VM Regions Near 0x12369aa80:
    MALLOC_TINY 0000000123500000-0000000123600000 [ 1024K] rw-/rwx SM=PRV
    –> VM_ALLOCATE 0000000123600000-00000001236e7000 [ 924K] rw-/rwx SM=COW
    mapped file 00000001236e7000-00000001239a6000 [ 2812K] rw-/rwx SM=COW /System/Library/Fonts/Helvetica.dfont
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0 libsystem_kernel.dylib 0x00007fff91b87d46 __kill + 10
    1 com.adobe.dvacore.framework 0x00000001046cf21a (anonymous namespace)::SignalHandler(int, __siginfo*, void*) + 314
    2 libsystem_c.dylib 0x00007fff8884694a _sigtramp + 26
    3 ??? 0x000000012369aa80 0 + 4889094784
    4 com.adobe.Encore 0x0000000100158565 MLFPlaybackHelper::CreateVideoTrack(TrackEditor const&, boost::shared_ptr) + 151
    5 com.adobe.Encore 0x000000010015b152 MLFPlaybackHelper::CreateSequence(PGCEditor const&, boost::shared_ptr, bool, int, int, dvacore::geom::PointT, long long, encore::FieldType) + 618
    6 com.adobe.Encore 0x0000000100158cd2 MLFPlaybackHelper::GetSequence(PGCEditor const&, boost::shared_ptr, bool, int, int, dvacore::geom::PointT, long long) + 1382
    7 com.adobe.Encore 0x00000001001617b0 MLFPlaybackHelper::GetSequence(GUOM::Timeline const*, boost::shared_ptr, bool) + 182
    8 com.adobe.Encore 0x000000010057ff76 AuthorContext::EditingServices::InternalCreateTimeline(AuthorContext::StEditingServicesUndoHelper&, GUOM::Timeline*) + 448
    9 com.adobe.Encore 0x000000010058060e AuthorContext::EditingServices::CreateTimeline(std::string const&) + 212
    10 com.adobe.Encore 0x000000010053ab2f GUOM::Timeline::CreateTimeline(GUOM::ProjectItemContainer*, GUOM::Timeline**) + 501
    11 com.adobe.Encore 0x00000001002d62ce ProjectCommands::CreateTimelineHelper(UndoSupport::UndoCookieJar&, GUOM::ProjectItemContainer&, std::basic_string const&, std::list const&, std::list const&) + 77
    12 com.adobe.Encore 0x00000001002d7b15 ProjectCommands::AddTimelineHelper(UndoSupport::UndoCookieJar&, GUOM::ProjectItemContainer&, std::list&, UISupport::ProgressStepper*) + 2029
    13 com.adobe.Encore 0x00000001002d904f ProjectCommands::CreateTimelineFromCurrSelection(Document*, exo::selection::Manager*, bool) + 215
    14 com.adobe.Encore 0x00000001002b0067 encore::ProjectCmdAttachment::DoHandleCommand(int) + 839
    15 com.adobe.exo.framework 0x00000001055b25ff exo::uisupport::CommandHandler::HandleCommand(int) + 239
    16 com.adobe.exo.framework 0x00000001055b183a exo::uisupport::CommandHandler::DoCallMyCommandChain(int) + 26
    17 com.adobe.exo.framework 0x00000001055b0bcc exo::uisupport::CommandHandlerBase::CallCommandChain(int) + 34
    18 com.adobe.Encore 0x00000001002fbbf5 encore::ProjectTabController::DoContextMenu(Attribute::Bag*, dvacore::geom::PointT const&, dvaui::ui::UI_Node&) + 8143
    19 com.adobe.UIToolkit.framework 0x000000010685a7df exo::hierarchyview::BasicMultiColumnList::DoContextMenu(dvacore::geom::PointT const&, dvaui::ui::UI_Node&) + 79
    20 com.adobe.UIToolkit.framework 0x000000010685a78b non-virtual thunk to exo::hierarchyview::BasicMultiColumnList::DoContextMenu(dvacore::geom::PointT const&, dvaui::ui::UI_Node&) + 13
    21 com.adobe.exo.framework 0x00000001055af06f exo::trackview::TrackView::ContextMenu(dvacore::geom::PointT const&, dvaui::ui::UI_Node&) + 83
    22 com.adobe.exo.framework 0x00000001055ad864 exo::trackview::DVATrackerCapture::DoMouseEvent(dvaui::ui::MouseEvent const&) + 542
    23 com.adobe.dvaui.framework 0x0000000104be89dd dvaui::ui::UI_Node::UI_DispatchCapturedMouseEvent(dvaui::ui::MouseEvent const&) + 425
    24 com.adobe.dvaui.framework 0x0000000104be8c5c dvaui::ui::UI_Node::UI_DispatchMouseEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&, bool) + 118
    25 com.adobe.dvaui.framework 0x0000000104be8d0f dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent const&, bool) + 63
    26 com.adobe.dvaui.framework 0x0000000104c505e2 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 702
    27 com.adobe.dvaui.framework 0x0000000104c4e7aa dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 470
    28 com.adobe.dvaui.framework 0x0000000104c4d3c9 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 123
    29 com.adobe.dvaui.framework 0x0000000104c4ea98 dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 28
    30 com.adobe.dvaui.framework 0x0000000104c4b577 dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 57
    31 com.adobe.dvacore.framework 0x00000001045db9de int dvacore::config::ErrorManager::ExecuteFunction(boost::function0*, void*) + 28
    32 com.adobe.Encore 0x0000000100227224 dva::encore::DroverErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0) + 52
    33 com.adobe.dvacore.framework 0x00000001045db8d0 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0, bool*) + 112
    34 com.adobe.dvacore.framework 0x00000001045dde0d void dvacore::config::ExecuteTopLevelFunction(boost::function0, bool*) + 125
    35 com.adobe.dvaui.framework 0x0000000104c447bf -[DVAMacContainerView mouseUp:] + 127
    36 com.apple.AppKit 0x00007fff8b236606 -[NSWindow sendEvent:] + 7053
    37 com.apple.AppKit 0x00007fff8b232674 -[NSApplication sendEvent:] + 5761
    38 com.adobe.dvaui.framework 0x0000000104c3e586 -[DVAMacApplication sendEvent:] + 630
    39 com.adobe.exo.framework 0x00000001055571c3 -[ExoMacApplication sendEvent:] + 563
    40 com.apple.AppKit 0x00007fff8b14824a -[NSApplication run] + 636
    41 com.adobe.exo.framework 0x0000000105557729 exo::app::OS_AppBase::RunEventLoop() + 55
    42 com.adobe.Encore 0x0000000100347260 main + 399
    43 com.adobe.Encore 0x00000001000497e8 start + 52
    Does anyone know how to solve this problem?
    Fernando Coelho replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
