Activity Forums Adobe Encore DVD Encore CS6 Skipping Last Button
  • Encore CS6 Skipping Last Button
    Posted by Sam Bennett on July 28, 2015 at 2:53 am
    Hi all, I have a problem where the last button on my menu is always skipped. NO I don’t have automatic button routing on. All of my button routes are set up correctly. i.e: when button 5 is highlighted and I press the down arrow, button 6 becomes highlighted. That’s how it should be. But pressing the down arrow from 6, I am not taken to button 7, but straight back to button 1. If I delete button 7 altogether, the issue occurs with button 6 (the now last button on the menu)
    All buttons are within the safe zone and are an equal safe distance apart from each other
    The menu was made in photoshop with the appropriate folder structure and naming conventions. Button type is ‘Normal’ I’ve trashed prefs and re-installed as well. And tried multiple computers. I can see the issue in the Encore preview window, a build videoTS folder and a burnt disc.
    This is a BRD project, the problem doesn’t occur with DVD.
    Any answers, help, suggestions are very welcome and appreciated. Sam.
    Sam Bennett replied 11 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
