Activity Forums Adobe Encore DVD Encore CS5 crashes a few seconds after starting
  • Encore CS5 crashes a few seconds after starting
    Posted by Paul Van der bergen on December 7, 2011 at 3:59 pm
    Hi !
    I’ve a huge problem with Adobe Encore CS 5:
    The program starts, I can make a new project, but after 5-10 sec., it crashes. Even if don’t do anything (e.g import or make a menu), it just shuts down and I get an error-message.
    I deactivated the DVD-Player, deleted the appdata, made a new user, opened as administrator, deactivated the windows-compatibility mode, disabled startup items, deleted AdobeFontfiles and removed the plugins from the Encore-Folder…
    so basically everything I found on the Adobe troubleshooting page and in forums. It didn’t help.
    What else I can I try ?
    I’m running Windows 7, 64 Bit on a Dell M6500,
    Intel i7, 1,73 GHZ, 8GB Ram, with a NVIDIA QUADRO FX 3800M.
    Thanks a lot for any suggestion!
    Paul
    John Mchugh replied 14 years, 8 months ago 3 Members · 2 Replies
  • Ricky Barrow
    December 7, 2011 at 6:27 pm
    Check nvidia drivers
    Ricky
  • John Mchugh
    January 8, 2012 at 1:41 pm
    I had about the same problem. What I started doing is to make a DVD image since I need a copy also. Once the image was created, it takes several minutes to burn the DVD.
    I hope this helps.
