Activity Forums Adobe Encore DVD Encore CS4 + Windows 7
  • Encore CS4 + Windows 7
    Posted by Clint Milner on May 7, 2010 at 4:32 pm
    Has anyone tested Encore CS4 with Windows 7?
    I’ve read that people had problems with the beta of Windows 7, but I was wondering if there were any users that have used Encore on the a final build of Windows 7?
    I have a choice of using Windows 7 Pro 32bit or Windows 7 Ultimate 64.
    Clint
    Adobe CS4 Master Suite
    Vista Ultimate 64 SP1
    Intel Core i7 920 @ 3.60GHz
    12 GB DDR3 RAM
    NVidia Quadro FX 3700
    Matrox RT.X2 LE Capture Card
    4 TB RAID 5
    Clint Milner replied 16 years, 3 months ago 3 Members · 4 Replies
  • Minu Sharma
    May 10, 2010 at 5:37 am
    Hi Clint ,
    There are some issues on windows 7 with CS4.
    Reason :
    Encore installs an older version (not compatible with Windows 7) of the Roxio pxhelp driver
    Workaround :
    Install an updated version of the pxhelp driver from Roxio. The updated driver is available .
    or
    Disable or disconnect any internal or external Blu-ray or DVD burners.
    Please have a look at:
    https://kb2.adobe.com/cps/516/cpsid_51665.html
    I am sure it will help.
    Minu
  • Rajesh Lamba
    May 14, 2010 at 7:37 am
    Hi Clint,
    I have been using Encore CS4 on Windows 7 and it works fine. However it is good to know about the Known issues with workaround from adobe knowledge base articles. here are some important ones.
    https://kb2.adobe.com/cps/516/cpsid_51665.html 37k
    https://kb2.adobe.com/cps/516/cpsid_51664.html 37k
    https://kb2.adobe.com/cps/516/cpsid_51663.html 36k
    As far OS is concerned, I would recommend Windows 7 Ultimate 64. So give it a try.
    Thank you,
    Rajesh
  • Clint Milner
    May 14, 2010 at 9:13 am
    Hi Minu,
    Thank you for the reply, it was very helpful, and when I get around to rebuilding my laptop, I’ll make sure to get that file.
    Cheers,
    Clint
    12 GB DDR3 RAM
    4 TB RAID 5
  • Clint Milner
    May 14, 2010 at 4:16 pm
    Very helpful,
    Thank you for the info Rajesh.
    Clint
    12 GB DDR3 RAM
    4 TB RAID 5
