Activity Forums Adobe Encore DVD Encore CS4 encodes HD as SD in Flash?
  • Encore CS4 encodes HD as SD in Flash?
    Posted by Phil Condit on May 22, 2012 at 12:32 am
    I am trying to create a high quality 1280 x 720, 16×9 Flash movie file from my widescreen .m2v timeline in Encore CS4. In the resulting Flash folder the source files appear correct, but when I play the Flash movie it is in 4:3 ratio, chopping off the right and left of the frame. What am I doing wrong?
    I am on a PC running Windows XP.
    Phil Condit replied 14 years, 3 months ago 2 Members · 4 Replies
  • Eric Pautsch
    May 22, 2012 at 2:09 am
    DVD is 720×480 so your Flash will be as well. Regardless, its best to do your flash project separately. The DVD to Flash option is not a good workflow and often doesnt work correctly
  • Phil Condit
    May 22, 2012 at 5:23 pm
    Hi Eric,
    Thanks for getting back to me. However, I am a little unclear about your response.
    You say that DVD is 720×480 so my Flash will be the same. That makes perfect sense, but my DVD displays the image as 16:9 where the Flash displays it as 4:3 with the sides cut off.
    When you say it is best to do the flash project separately, do you mean to have Encore compress the original HD footage using Flash output – or should I not be using Encore at all? And if not, What should I use?
    Thanks for you help!
    -Phil
  • Eric Pautsch
    May 22, 2012 at 6:34 pm
    Yes….DVD is 720×480 16×9 Anamorphic so the Flash Project you make out of Encore will be the same. Maybe someone else will chime in on why one is 4×3 and one is 16×9? Encore is a very buggy tool and DVD to Flash conversion is not a good workflow. wish I had a better answer
    Use Flash to make a Flash project. I think Adobe just included that option to make proofing easy for clients….its not designed to make full fledged Flash Projects…..Thats what Flash is for 🙂
  • Phil Condit
    May 22, 2012 at 7:58 pm
    Thanks for the advice. I will hop on Lynda.com and review the Flash tutorials.
