Activity Forums Adobe Encore DVD Encore CS3 Help Photo Gallery
  • Encore CS3 Help Photo Gallery
    Posted by Andy Ireland on November 4, 2009 at 11:47 am
    Hi guys.
    Looking for a bit of help.
    I have already browsed the other threads on this topic but they date back years.
    I’m looking to make a DVD image gallery for a client, with hundreds of images. How will Encore CS3 cope with this? I have used it to create DVD menus before for video work I have done and found it simple enough to use.
    Is it the best software to use for a job like this? It has to be playable in a DVD player and a PC.
    Is there anyway of animating between images from clicked links for example?
    What kind of image should I import and for best quality what is the best settings?
    Any advice/help most appreciated
    Thanks in advance.
    Andy
    Andy Ireland replied 16 years, 10 months ago 2 Members · 4 Replies
  • John Rich
    November 5, 2009 at 12:00 pm
    What I’d consider, since you are only doing a slide show is using ProShow Gold instead of Encore.
    You could try a free trial. They also have tutorials, and sort of “Presets” which are interesting, but I don’t think there are trials of the presets or tuts.
    John Rich
    JOHNR
  • Andy Ireland
    November 6, 2009 at 3:00 pm
    Thanks for the response John.
    Could I not just as easily do that in Premiere Pro?
    With that I would surely have more control?
    What are your experiences with this?
    Thanks again,
    Andy
  • John Rich
    November 6, 2009 at 7:26 pm
    Andy,
    I’ve never used Premiere for this. When you said picture gallery, I assumed you meant a slide show type thing. Since you have hundreds of images, it just seemed a lot of work to set it up in Premiere. While you can set a single transition for each one in Premiere, in ProSho, you can set random transitions and it also has a variety of more elaberate transitions. You then generate the DVD directly in ProSho. You can set the sound track to directly reflect the length of the slideshow ie set a slide / second automatically.
    (Sorry to ramble and I don’t have any connection to Proshow, I just like it for slide shows).
    If you wanted to use an Adobe Product, I’d consider After Effects per this tutorial https://www.videocopilot.net/tutorials/elegant_slideshows/
    John Rich
    JOHNR
  • Andy Ireland
    November 9, 2009 at 9:18 am
    Thanks again for the response John.
    I think for chaptering purposes, I am going to do it in Premiere – creating different timelines for each product shouldn’t be too daunting I hope!!
    After Effects would be a brilliant method, but a lot more time consuming I imagine.
    Cheers.
    Andy
