Activity Forums Adobe Encore DVD Encore CS3 – C++ Runtime Error? Please Help
  • Encore CS3 – C++ Runtime Error? Please Help
    Posted by Stephen Rutherford on April 22, 2008 at 9:24 pm
    Please help if you know what this means.
    I was working with a project and Encore kept locking up and I would “end task”/force quit to dump the program. When I tried to open my project again, this error comes up.
    I am up against a Friday deadline…
    Thanks.
    Stephen Rutherford
    Graphics Producer: Gale Force Media, CanesVision & Wolfpack TV
    stephenr@carolinahurricanes.com
    CAROLINA HURRICANES: 2006 STANLEY CUP CHAMPIONS!
    Christiaan Benus replied 16 years, 3 months ago 3 Members · 4 Replies
  • Jeff Bellune
    April 22, 2008 at 9:47 pm
    Do you have any kind of USB stick/thumbdrive attached?
    Do you have a CD-ROM or CD-RW drive attached to your computer? If so, try disabling it through Device Manager temporarily and see if that helps.
    Finally, read all of the posts in this Adobe U2U Forum post
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Stephen Rutherford
    April 22, 2008 at 10:28 pm
    Nothing external… I have two internal drives, one CD-R and one DVD-R. I disabled the CD-R and it is still having issues.
    I acutally began building my project from the ground up after this, and things were going well until I imported the subtitles…
    The “End Now” dialog popped up and when I clicked to “learn more” about the problem, the following was generated (two seperate instances noted):
    INSTANCE 1
    AppName: adobe encore.exe AppVer: 3.0.1.8 ModName: sonicauthorcore.dll
    ModVer: 3.0.0.268 Offset: 004e4e20
    INSTANCE 2
    ModVer: 3.0.0.268 Offset: 004e5f18
    I’m guessing the “sonicauthorcore.dll” is screwy? Should I attempt to re-install this particular .dll (or even Encore alltogether)?
    Thanks again!
    Stephen Rutherford
    April 22, 2008 at 11:44 pm
    I just reinstalled Encore from the CS3 DVDs… It said it successfully repaired Encore. However, I still got an error message when I attempted to open my project:
    AppName: adobe encore.exe AppVer: 3.0.1.8 ModName: backendlib.dll
    ModVer: 3.0.0.0 Offset: 003964ed
    Different ModName .dll from before with the same results.
    Stephen Rutherford
  • Christiaan Benus
    May 25, 2010 at 2:12 pm
    hi,
    my name is Christiaan and i am from Europa.
    i have the same problem as you do.
    i found a temporary solution to the problem.
    make a new Windows account whit administrator rights.
    now i can us encore again.
    greetings, Christiaan
    hi
