Activity Forums Adobe Encore DVD Encore Crashing on Blu Ray Transcoding…..
  • Encore Crashing on Blu Ray Transcoding…..
    Posted by Martin Slidder on March 15, 2011 at 2:21 pm
    We need some urgent help…..
    We’re using an 8-core Mac Pro (OS Leopard) with Final Cut Studio 3 &
    Adobe Production Suite CS4. We shoot on 5Ds and EX3s, transcoding the
    5D material to ProRes LT using Canon’s plugin for FCP, then export our
    finished videos from the timeline in full quality.
    In the past we’ve tried using Compressor to make the H264 assets for
    Encore, but Encore hung for 10 minutes or so (or crashed completely)
    every time we pulled in even a single asset, so that’s a no-go.
    Our workflow now is that we pull the full-quality mov files into Adobe
    Encore and have Encore transcode all the assets to H264 itself and
    build a bluray ISO which we then burn (usually to a dual-layer 50GB
    disc – there can be as much as about 4 hours we need on a single
    disc).
    That was working fine for the last few projects, but the issue we’re
    having now is that we set the build process off and leave it to run
    overnight (because of the time it takes to transcode), but when we
    come back in the morning Encore has crashed and there’s just the OS X
    error message telling us that Encore has crashed and would we like to
    send a report. We know that the motion menu has rendered fine, because
    we’ve seen that that is working before we’ve left it to run overnight.
    We haven’t updated any software since it was last working, and our
    workflow hasn’t changed. We’ve tried restarting, re-building the
    Encore project, we’ve made sure there’s plenty of space on all of our
    drives.
    It’s not an option to re-install everything at this point (because the
    client is waiting and is becoming impatient), but is there anything
    anyone can suggest that we haven’t tried, because we’ve hit a wall!!!
    Daniel Ludwig replied 15 years, 6 months ago 3 Members · 2 Replies
  • Jeff Bellune
    March 15, 2011 at 3:33 pm
    Delete the AuthorScriptHDMVSessions folder that’s in the En project folder and try again.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Daniel Ludwig
    March 17, 2011 at 9:35 am
    hey martin,
    I never had any issue while importing assets created with compressor into encore CS4 or CS5.
    if you have choosen the right project-settings your assets wont be transcoded.
    it´ll take a LOT time to import, depending on the duration of your film. encore will create meta-datas while importing the h264-assets onto your system-drive.
    please have a look at your preferences>media you should clean the media cache if you have trouble with the meta-datas.
    if you have a PC or bootcamp by side you can also choose to have a look at EasyBD from DVD Logic. you can create spec-level BDs and if you need to have some nice menus you could do this with IGEditor.
    https://www.dvd-logic.com/
    cheers and good luck
    danny
