Activity Forums Adobe Encore DVD Encore Chapter Links set correctly, but going to Main Menu, Why??
  • Encore Chapter Links set correctly, but going to Main Menu, Why??
    Posted by Adam Berch on April 28, 2013 at 8:52 pm
    I am working in Encore CS 5.1
    I have built a 9 menu Blu-Ray DVD with a 2 and a half hour wedding as the project.
    I linked everything up and it should be ready to burn.
    When I went to Preview it and make sure all the links work, most of them did.
    A few of them would go back to the main menu for some reason.
    Let me explain, I am testing out the links and mostly all worked fine. When I press some of them, they would play for about a second then go back to my main menu.
    Why is this happening?
    I linked up all the buttons to the chapters the right way.
    Should I just go and burn the DVD as a test to see if it’s working correctly or not?
    If not, what should do?
    Thanks in advance
    Encore CS 5.1
    Adam Berch replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
