Activity Forums DVD Authoring Encore can’t import QT Reference file as asset
  • Encore can’t import QT Reference file as asset
    Posted by John Doyle on December 2, 2008 at 6:50 pm
    Encore CS3 is refusing to import a QuickTime Reference file as an asset, giving this error message:
    “Could not import the file filename.mov. QuickTime and/or the appropriate codec do not appear to be installed.”
    I have previously imported these same .mov assets with no problem.
    I uninstalled & re-installed QuickTime and the entire CS3 Suite. No remedy.
    I have a stable XP system. The only major change is that I upgraded Avid XpressPro from 5.7 to 5.8. Could this possibly have broken the QT codecs?
    Any suggestions much appreciated.
    John Doyle replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
